Can I Run A New Hot Water Line Off A Tee - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2009, 12:36 PM   #1
Rewards Points: 174
Can I run a new hot water line off a tee
My water heater has a tee with a 1/2" pine that is capped. It is the very first tee on the line. I am not sure if it is there for a reason or just as a future connection.
Can I go ahead and remove the cap and run my hot water line off of it or am I better off cutting the line a few feet away and starting a new tee?
Thanks.
Leo
Leoskee is offline   Reply With Quote
Old 09-12-2009, 12:50 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
If its just capped off and is big enough for what you need then I dont see any reason not to use it.
JDC is offline   Reply With Quote
Old 09-12-2009, 01:47 PM   #3
Not a plumber but could it be there for water hammer?
Mike in Arkansas is offline   Reply With Quote
Old 09-12-2009, 06:32 PM   #4
Rewards Points: 174
Thats exactly what I thought. The only thing is that the water hammers I have seen are longer and are round at the end. This is just a 1/2 pipe with a cap on soldered onto it.
Old 09-13-2009, 03:52 AM   #5
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
I doubt its an air chamber due to its location and length. Besides, air chambers dont work very well for preventing water hammer. Use the tee. If later on you develop water hammer then you can install a true water hammer arrestor.
Old 09-13-2009, 10:25 AM   #6
You just have to defer to someone who actually knows what they're talking about.
Need Assistance - Broke valve where water line feeds to Fridge... BDPNA Plumbing 7 08-10-2009 08:38 PM
Running water line for Refridgerator.. dirtmcgirt79 Plumbing 1 06-18-2009 10:27 AM
How to Install a Water Line to a Refrigerator With No sink yerac2003 Plumbing 6 05-07-2009 03:27 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 05:34 AM
