Can I Run A Bathroom Vent Out The Gable End Vs Through The Roof? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2011, 07:27 PM   #1
msaeger's Avatar
Rewards Points: 260
Can I run a bathroom vent out the gable end vs through the roof?
Can I run a bathroom vent out the gable end vs through the roof? 12x12 pitch roof so no one wants to go up there :-)
msaeger is offline   Reply With Quote
Old 11-24-2011, 07:39 PM   #2
Rewards Points: 2,516
You referring to a exhaust fan vent or a fixture vent?
hammerlane is offline   Reply With Quote
Old 11-24-2011, 07:45 PM   #3
msaeger's Avatar
Rewards Points: 260
Fixture vent. I will have to run a fan too though.
Old 11-24-2011, 07:53 PM   #4
Rewards Points: 582
i would think fixture vent would have to go through roof according to plumbing code....fan vent could exit through side wall...
Old 11-24-2011, 08:18 PM   #5
Both can go out gable end.
Regarding the fixture vent the simple answer is yes with some limitations that you should double check with local inspector. In general here are some points:
For fixture vent make sure:
-it is at least 3 feet from property line, street, etc.
-keep end 10 feet from any doors/windows
-in most jurisdictions it must terminate downward
-make sure you screen the end
Old 11-24-2011, 08:24 PM   #6
If it were me, I would find another plumbing vent in the attic and tie the new vent into it rather than cutting another hole in my roof
Service plumber is offline   Reply With Quote
Old 11-24-2011, 08:44 PM   #7
msaeger's Avatar
Rewards Points: 260
I wish there was one to tie into the ones from the lower level go out lower than the ceiling of the upper level. This is a cape cod.
I think I might not be able to get far enough from the window :-(
Old 11-24-2011, 09:13 PM   #8
Rewards Points: 582
I really don't think you should vent through side wall....just go through roof its really not that bad..and should not cost that much ..and it would be the better way to vent......
Old 11-24-2011, 10:45 PM   #9
msaeger's Avatar
Rewards Points: 260
Who would do it a roofer or a plumber?
Old 11-24-2011, 11:14 PM   #10
Plumber
Old 11-25-2011, 06:36 AM   #11
Either could install the roof vent. I'd have a roofer do that part. If you're set on running the fixture vent out the roof but are hesitant to go up there because of the pitch here's what you do:
Have supplies ready(stack and stack flashing). Keep an eye in your neighborhood for someone having a roof done, talk to the MFIC(mother fudger in charge) on the site and ask them if someone from the crew could install the vent. Have about $75 cash in hand while asking.
If it was a flatter roof maybe $50.
Old 11-25-2011, 07:58 AM   #12
Rewards Points: 582
really all depends how far up the roof the flashing is going to be ..sometimes we was able to install off ladder......and yes let a good plumber do it .....
Old 11-25-2011, 08:41 AM   #13
Just call me Andrew
Rewards Points: 1,020
There is nothing wrong with venting a bath fan out the gable end...and that's exactly what I plan to do for my parents rather than put a hole in their roof.
Andrew
secutanudu is offline   Reply With Quote
Old 11-25-2011, 11:30 AM   #14
I think his main concern is fixture venting out the gable.
The Following User Says Thank You to hammerlane For This Useful Post:
secutanudu (11-25-2011)
Old 11-25-2011, 01:12 PM   #15
Studor?
broox is offline   Reply With Quote
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 03:45 PM
New Roof marknok Roofing/Siding 4 08-06-2011 12:41 PM
86 the Gable Vent??? 11thHourZero Roofing/Siding 5 07-17-2011 08:09 PM
How hard is it to add a roof vent with no experience? Red Squirrel Roofing/Siding 3 05-18-2010 10:35 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
