Can I Raise The Height Of A P Trap Arm? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2013, 08:14 PM   #1
Rewards Points: 77
Can I raise the height of a p trap arm?
I have the opposite problem that is pictured in the attached image (although not as bad). I'm wondering if I can raise the height of a p trap arm to meet up with a san tee?
nateo is offline   Reply With Quote
Old 01-15-2013, 08:40 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 440
If you mean shorten the sinks tailpiece- yes
Old 01-15-2013, 09:19 PM   #3
Rewards Points: 77
Actually I'm putting in a p trap under the bathtub, no compression fitting on this one. Can't shorten the vertical (tailpiece) pipe. I'm wanting to raise up the 90 that connections to the U
Old 01-15-2013, 09:28 PM   #4
Plumber
Rewards Points: 440
You can but it is not allowed by code. There is a maximum trap depth- I believe its 4" The reason for this is that a trap must be "self cleaning" Making it deeper allows solids to settle rather then flushing out while draining- or so I'm told...
Also, your 90 will determine the depth of the water seal- will it be higher then the base of your tub? If so, you'll always have standing water in your tub
Old 01-15-2013, 10:33 PM   #5
Roofmaster
Rewards Points: 2,172
Am I losing it? From that picture it looks like the tailpiece has to be extended so the back of the trap lines up with the T? I cant see anything wrong with that.
Old 01-15-2013, 10:38 PM   #6
Plumber
Rewards Points: 440
Yeh, you're losing it. He wants to do the opposite. In fact, as I understand it, he wants to make the adjustment at the trap by making it deeper
Old 01-16-2013, 12:06 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Looks to me he needs to add length to the tail piece to bring the trap down to the tee. Or move the tee up. Either one will work.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
jagans (01-16-2013)
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 01:39 PM
Please advise on using Lauan to raise my subfloor height. chrisrod Flooring 4 11-04-2010 08:20 PM
Raise the height of my sub-floor in prep for laminate flooring chrisrod Flooring 0 10-30-2010 04:56 PM
Need to raise counter height over existing kitchen cabinets Eric Adams Carpentry 6 07-12-2009 02:38 PM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 08:30 PM
