Can I Move Toilet Drain Into Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2012, 04:04 PM   #16
Originally Posted by Evstarr View Post
You'd have to cut off the flange, attach a 90, run new pipe sloping up, add another 90 pointing up, attach a new flange, box in the pipes and build a sturdy platform about 16 inches high to sit the toilet on top of, which means steps.
Hmm come to think of it, that really would be a throne wouldn't it?
Plus with all those turns, it would tend to clog. And, if takes you more than about 5 feet, you'd have to open the floor any way to remove the existing trap and move it to the new location because you can't have 2 traps on a fixture.
lol yea it would but i will be buying a new toilet that has a rear end drain like this (though not that expensive/high-tech)
I never thought of the clogging, it'll have 3 turns. and yea itll move about 3-5ft
also this is a gut job, a lot of walls are already down cause of mould
Toilet Bowl is offline   Reply With Quote
Old 06-28-2012, 04:06 PM   #17
Renovations contractor
Bonzai's Avatar
Not to mention reframing the wall to build it out far enough to run the correct diameter of pipe in the wall which includes being able to make a turn from the
wall to come out to the toilet while the whole time maintaining a slope. There's a reason licensed plumbers the world over install toilets in much the same way ... and in Canada sh#t still flows downhill (and not great round a loop of 90 degree turns)
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
The Following User Says Thank You to Bonzai For This Useful Post:
Evstarr (07-07-2012)
Tags
moving plumbing , toilet
Moving my Toilet Drain and Installing a Shower Drain Hahny Plumbing 3 04-13-2011 12:22 PM
wall mounted residential toilet kr bennett Plumbing 10 12-05-2010 11:03 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Move basement toilet rough in 6-8" HVACman Plumbing 5 04-19-2008 08:45 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
