#1 |
Can I Move Toilet Drain Into Wall?
Hello folks, I want to move my toilet but its on concrete and I really don't want to have to jackhammer it up. So my question is can I redirect it up into the wall thru the framing? Sorry I have zero knowledge in plumbing but will read up if I have to. Just wanted to know if its possible.
I want to move it to where the toilet paper thing is. The pipe coming up from the ground is no problem cause I would extend the shower (from the left side) all the way to the other wall (where the toilet paper is) and build a seating area to conceal it. ![]() ![]() the venting can be easily moved as well. |
#2 |
A whole lot of work for little gain.
The floor would have to be jack hammered out all the way under the wall, you would need at least a 6" thick wall for the drain pipe. |
#3 |
damn, I really need more space on the wall. as of now my max shower size can be 30" wide. I'm assuming If I were to build the wall out with another 2x4 I'd have sufficient space? Moving the toilet like this is pretty much my only viable option
#4 |
Bill Kearney
Just where do you think the toilet would drain where it to go "into the wall"? There are such things as toilets that recess their tank and have their drain in the wall cavity. They're not cheap and it still has to drain down to a sewer line. Where is the other line you'd use?
It'd be a lot simpler to just rent a jackhammer and do it right. Bust the floor, re-route the plumbing (properly) and concrete it over again. Honestly, if you didn't know enough to already know this answer, then perhaps you really should consider speaking with a local plumbing professional about it. Last edited by wkearney99; 06-27-2012 at 09:10 PM. |
#5 | |
Renovations contractor
Can I Move Toilet Drain Into Wall?Quote:
Home Renovations & Repairs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Vancouver to Whistler & beyond |
#6 |
I must be missing something, mounting it to the wall would not gain a single inch of space.
Even the way it is now looks like it was installed to close to the wall. http://homerenovations.about.com/od/...bathlayout.htm |
| The Following User Says Thank You to joecaption For This Useful Post: | Bonzai (06-27-2012) |
#7 |
Any by the way, you probably want to place a rag in that drain for now unless you find the smell of sewer gases something that particularly rocks your world
#8 |
its not practical to even do that....jack hammer the floor....
#9 |
Just took it out today, thanks for the tip on covering it, and the placement is fine, theres 15 and 15" to each side. Also I'll be buying a rear drain toilet, so the drain can come from the wall they're pretty much the same price
Heres my idea on paper, I think my post was misunderstood. All I wanted to know was If i could move the drain from the toilet to a new location by moving the drain thru the wall
#10 |
Ok so all the pros who have responded are telling you bad idea ... And also if you are in North America or UK (the areas I am generally familiar with) then this does not meet code in most if not all areas. Not only would you have to notch out studs in that back wall totally (is it a load bearing wall) but also you will have to raise the shower such that the curb would be a silly height. I guess if you want to spend way more time and money and end up with a bathroom that is not to code (depending where you are of course as we don't know) then go for it ... But if you actually want constructive feedback then jack hammer the floor and do it right.
#11 |
Bill Kearney
You're planning on running behind the wall and back into the existing toilet flange? And how do you expect that to work? As in, it will not work. Do not do this. Mistakes with sewage get expensive and nasty. Do not do this. If something goes wrong with your re-routed nonsense then you'll have to bust open the whole shower bench covering it.
Just do it the right way. Bust open the concrete and move the toilet flange properly. This is not a hard job. Fixing a half-ass nightmare WILL BE. |
#12 |
Super Moderator
Opening the slab with a jack hammer--3 hours tops---
Your plan will not pass code--it will be a drainage failure---and the elevated floor will look like a mess. By the time you allow for the shower P-trap your shower will be 10 inches above the floor--
New members: Adding your location to your profile helps in many ways.--M-- |
#13 |
alright I'll look into the jack hammer way, thanks
but to be clear, nothing is elevated. the drain pipe will be concealed under a shower seat and the wall is not load bearing, i was going to build it out to accommodate anyway. and i live in canada. |
#14 |
does someone wanna tell me why it'll fail tho? adding the pipe up, and behind a wall back out to the new location seemed like a quick fix to me
#15 | |
Hmm come to think of it, that really would be a throne wouldn't it? Plus with all those turns, it would tend to clog. And, if takes you more than about 5 feet, you'd have to open the floor any way to remove the existing trap and move it to the new location because you can't have 2 traps on a fixture. Last edited by Evstarr; 06-28-2012 at 04:01 PM. |
| Tags |
moving plumbing, toilet ![]() |
| Display Modes | |
| Moving my Toilet Drain and Installing a Shower Drain | Hahny | Plumbing | 3 | 04-13-2011 12:22 PM |
| wall mounted residential toilet | kr bennett | Plumbing | 10 | 12-05-2010 11:03 PM |
| Help me check my logic on clogged drain and overflowing toilet | Southlake_Ed | Plumbing | 10 | 01-05-2010 08:52 PM |
| Move basement toilet rough in 6-8" | HVACman | Plumbing | 5 | 04-19-2008 08:45 PM |
| Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* | J187 | Plumbing | 6 | 05-23-2006 12:13 AM |
