Can I Move My Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2013, 07:29 PM   #1
Can I move my water heater?
I'd like to move my water heater to another corner of the basement because it's taking up a lot of valuable space. If I move it I'll be able to put an oil furnace as a backup system since I already have an electrical furnace.
I'm I allowed to put it where I want? Are there regulations concerning the distance between the water heater and ... the electrical panel or an electric furnace, an oil furnace or the sewer??(don't know for sure what's it's called), windows or exterior walls because of the cold or anything else? I'm in Canada, province of Quebec, city of Montreal. Any input would be gladly appreciated.
Anyone know where I can find the building code online for the province of Quebec or is it by city.. then Montreal.
Girly_girl is offline   Reply With Quote
Old 03-16-2013, 08:05 PM   #2
Rewards Points: 13,978
Is it gas or electric?
Old 03-16-2013, 08:36 PM   #3
forgot to mention that... it's electric
Old 03-16-2013, 08:47 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You might need to drain it first. It's awful heavy.
Ba-dum-dum.
Journeyman Plumber
Old 03-16-2013, 10:01 PM   #5
Roofmaster
Rewards Points: 2,210
Sure! Ba-Da-Bing!
Old 03-16-2013, 10:50 PM   #6
Ba-dum-dum.
I don't know if you meant that as an insult (dum-dum part!!) but I AM offended!! Did you answer that because a girl is asking that question? Not as stupid as you may think if I'm thinking of doing it myself and reconnecting the plumbing and the electricity along with it! If it was meant as a joke you should have omitted the dum-dum part! Of course you have to empty it out duh! not even a man could move it around when it's full! And it's still heavy when it's empty I know I brought it in with a friend. I know!! That doesn't answer my question at all!!!
Old 03-16-2013, 11:08 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 802
A water heater requires access to the elements and other controls. It also requires an approved receptor to receive the T&P discharge.
You may not have this now and may be considered "grandfathered" into code compliance, but in my neck of the woods, when you alter piping or fixture locations- you must meet current code standards for T&P piping
I think electrical panels require 3' clearance in front and nothing above them- as in water lines- hope this helps some
Old 03-17-2013, 08:43 AM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 996
Alan was int being insulting its common to throw in a joke or smart Alec comment here and there, don't take it personally imagine your in a chat room with a bunch of plumbers, i personally think it great when a lady is not afraid to tackle challenging DYI project. this site has a bunch of great and knowledgeable people ready to help with great feed back, so don't get mad get working.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
Girly_girl (03-17-2013)
Old 03-17-2013, 08:50 AM   #9
Rewards Points: 1,536
OT: Dressers, shelf units, and cabinets should also be unloaded prior to moving otherwise the weight of the contents can put added stress that cracks the wood joints.
Old 03-17-2013, 09:14 AM   #10
What does this have to do with my question? I'm not asking about moving furniture and the damage it could do to the joists! I'm asking about things I have to consider if I move the water heater (which is in the basement) and regulations in the building code such as clearances to be observed and such.
Old 03-17-2013, 09:54 AM   #11
Doing it myself
Alan's Avatar
Ok Ok... ba-dum-dum was a rimshot sound.
Anyway... You really shouldn't have any clearance issues. I'm not sure about what the codes say in canada, but where I live for an electric water heater, the only thing you do need is a 24" opening to the area where the water heater is. If it's located in an attic or a basement, you need to have a permanent light with a switch located near the opening.
Extending the water lines shouldn't be an issue. You can pretty much put them anywhere. Just use common sense.
Journeyman Plumber
Old 03-17-2013, 11:03 AM   #12
Roofmaster
Regardless of whether you are female or male, black, red, green, or white, there was no way on earth that your question could have been answered with the information you posted. You posted no pictures of where you intended to place the water heater, no pictures of access to piping. No pictures of your breaker panel or available unused amperage in your panel, so what did you expect as an answer.
The only response could be what you got. You would have gotten the same response regardless of your gender or color, because of the information, or lack thereof, that you provided, unless of course you would prefer that we treat you extra special and with kit gloves because you are a girly girl. Is that what you really wanted?
I doubt it
Tags
water heater
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
Question on return line for water heater daluu Plumbing 10 09-09-2012 10:38 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
