I bought a house about 3 and a half years ago, which has a large addition on the 2nd floor only. The addition consists of a family room and a master suite. I checked to make sure the addition was permited, but I didn't think to look specifically that the bath was part of that permit. I've since determined that it was not (the bath does not show up in the cities records, and when I look at the drawing supplied with the permit, the bath is not there, the space appears to have been originally built as a walkin closet, and later converted to a bath).
I'm perfectly happy to open a permit and have the bathroom inspected, I want to do some upgrading in there anyway. My concern is that because the addition is only the second floor, their is a large, open space under the entire thing. This concerns me because I've heard that it is not code to run water lines through soffets (don't know if that is correct, I've not yet read up on plumbing codes), and I'm afraid they will say that this situation is not much different. Presently, the plumbing is all in, and they did not disturb the joists when installing. They basically attached long, roughly 16 inch deep box under the joists, to make room for, and fully enclose/insulate the plumbing. Basically, the underside of the entire addition is closed in with 1/2 inch plywood. They opened up the section under the bathroom and built the 16 deep enclosure under there. It looks like a bulk-head if you are walking under the addition.
Any thoughts about what it would take to get this bathroom permitted/legal? Do I need to build a bump-out of the 1st floor, so that their is a heated "room" under the plumbing? Can I just open up that bulk-head to the interior of the first floor? Any other ideas?
I'm sort of hoping someone will tell me I'm blowing this out of proportion and that all I need is to open it up for the inspector and it will be that easy, but I'm doubting that for now...
Thanks!
Paul
Thanks!
Paul
