Can I Drain Two Toilets On A 3" Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2014, 09:36 PM   #1
Rewards Points: 89
Can I drain two toilets on a 3" pipe?
I live in New York State, but not New York city. Based on my research, NY state uses the 2010 ICC code.
In the basement, I have an under slab 4" pipe that transitions into a 3" pipe. On the first floor, I will be installing a toilet and a lavatory sink. On the second floor, I want to install a toilet, lavatory sink, and shower.
My questions are as follows:
1. First, can I install two toilets on the 3" drain line? Or, must I replace the 3" with 4"?
2. I was planning on installing a double-wye connector under the toilet on the first floor, with one Y-leg heading to the second floor in 3" (for the second toilet, shower, and lavatory sink), and the second y-leg will be used for the first floor sink drain, which I will convert into 1 1/2".
3. If I do install two toilets, what size vent must I use--2" or 3"?
4. Where do I install the vent for the first floor toilet and sink? Can I put it on the second wye leg?
Thanks,
Todd
Last edited by toddmanqa; 02-01-2014 at 09:38 PM. Reason: Meant title to say 'Can I drain two toilets on a 3" pipe'
toddmanqa is offline   Reply With Quote
Old 02-01-2014, 11:02 PM   #2
Rewards Points: 1,854
You will need to vent both baths and you cannot do the double y because you are eliminating your wet vent on that toilet which would be the lav. A bathroom layout must always be toilet then vent then third connection in your case could you use a tee vertical on the first floor. Top going to second floor a 3 by 2 y on the first floor with 2 inch to the lav then pick up your toilet. The vent on the first floor lav should be 2 inch and tie into the second floor vents 42 inches above the floor of the second floor.
Old 02-02-2014, 07:11 AM   #3
Rewards Points: 89
Like this?
Is this what you meant?
http://imgur.com/Nxkj8ju
Old 02-02-2014, 01:09 PM   #4
No thats a tee not a y fitting for the lav. You can never use a tee on its back or sideways to pick up any drainage. Only can be used in the vertical position. Like your 3 inch tee.
Old 02-02-2014, 11:23 PM   #5
Rewards Points: 89
Graphic fixed
Ok. How about this?
Old 02-03-2014, 07:22 PM   #6
Single lav only needs 1.5 inch to it.
Old 02-03-2014, 10:24 PM   #7
Lord of Slums
Rewards Points: 1,974
how did you make those pictures?
mj12 is offline   Reply With Quote
Old 02-04-2014, 11:21 AM   #8
Rewards Points: 89
Photoshop
Those pictures were made with Photoshop and images pulled off of Google search.
Old 02-04-2014, 07:48 PM   #9
Your vent size will depend on distance out the roof. > 40' 2 inch
Otherwise 1.5 inch.
Old 02-04-2014, 09:23 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 994
post a rough shop drawing if i am thinking, what your wanting to do its not correct.. venting and sanitary must be kept independent on each floor.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Can I split a main drain vent stack? -- SpinFly Plumbing 14 08-15-2012 10:32 AM
3" drain vent pipe going thru shed roof amakarevic Building & Construction 1 02-08-2011 02:50 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Vent on sink drain? shumakerscott Plumbing 3 06-27-2009 10:32 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
