Can I do my own advanced plumbing and have it checked
I don't know of many plumbers who are going to 'check' your work...even if you pay them....there are things that could be wrong that you can't see from a visual inspection.
With that said.....no reason you can't do it.....in most cases, if it doesn't leak...you more or less got it right.
I would 'highly' suggest pulling a permit...the inspector will then inspect it to make sure it's done correctly.
But, before embarking on your task...do the research. If your doing copper.....read on copper pipe sweating...if doning PEX, read up on how it's done.
On your drains....your basically going to just replace what is there....so just make the new stuff look like the old.....but it's ok to post pics and let the guys hear chime in.....
Good luck and check back in with us on the progress.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
