Can I Cut Down A Fernco? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2009, 05:32 PM   #1
Can I cut down a Fernco?
Piece of pipe between two angled fittings is only 2" and I need to cut it to access the pipe. I want to use a Fernco in case I need to get in there again in the future but they are 4" long, recommendations? Can I cut it down as long as both screw clamps have enough to grab?
pauly1976 is offline   Reply With Quote
Old 07-09-2009, 06:28 AM   #2
Remodeling Contractor
not really, but you can slip it up all the way onto one pipe, then line the pipes up and slip it over so it centers over both pieces. So why the need to cut it?
bathroom sink drain connection wdrwmn Plumbing 3 03-14-2009 05:39 PM
Fernco waxless toilet seals Duane 70 Plumbing 8 01-02-2009 02:35 PM
Hubless coupling vs. Fernco Joe F Plumbing 3 09-20-2008 10:56 AM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 06:39 PM
fernco coupling farrington135 Plumbing 2 03-09-2007 10:12 AM
