-   -   Can I connect toilet drain to this drain pipe (http://www.diychatroom.com/f7/can-i-connect-toilet-drain-drain-pipe-43060/)
james739 04-22-2009 10:33 PM
4 Attachment(s)
Hello All,
I am planning to install a full bathroom in my basement, using part of my laundry room. I have a few questions that needs to be addressed before I proceed any further.
1. My laundry room is right below the power room. The drain pipe from the toilet in the power room terminates in the laundry room. I do not have a rough-in for a bathroom in my basement. However, I have these 3 pipes sticking out of the concrete floor, it is not logical for these 3 pipes to be rough-in because of the location and the setup. Can someone tell me what they are for? I have posted the pictures.
2. Can I connect the toilet that will be installed in the basement to the drain pipe coming from the power room? Since the drain pipe is already connected to a toilet in the power room, I am assuming it is already vented, and does not need to be vented again! Is my assumption correct?
3. I am looking to install a stand up shower. What is the average height of a bathroom with a stand up shower.
Thank you for your help!
KOHNSTRUCTION 04-23-2009 01:28 AM
i think you are correct in everything that you are saying.
if i'm understanding properly i think the pvc caps (the white ones)
could be clean outs, open one up and flush water hose in it to make sure, as wella s flushing the bathroom upstairs and see if the water is in that same line. try to just flush water not any doodies that may fly out of the clean out
the Pvc was done under the concrete slab prior to poring the cement while the ABS (the black one) was done after the house was up
interesting project let me know if i'm right
KOHNSTRUCTION 04-23-2009 01:31 AM
oh yeah the average height for a laundry room basement converion to a bath is...........what ever you got there now
james739 04-23-2009 07:52 AM
Thanks for the prompt reply Kohnstruction,
Do you know what the piping sticking out of the concrete with the black cover is in the 1st and 2nd images? Just to confirm, Can I tap into the drainage coming from the second floor power room?
Thank you!
Ron6519 04-23-2009 09:18 AM
Thank you!
You can open the floor and tap into it, but you also need to incorporate a vent. Every fixture in the bath needs a vent, so try to run a conceptual vent system to gather up all of them.
Ron
james739 04-23-2009 11:31 AM
Thanks Ron6519,
What I don't understand is, if the drainpipe for the toilet is already vented, and I am taping into it, why do I need to vent the drainage again. If venting, how would I go about venting from the basement?
Ron6519 04-23-2009 12:00 PM
Originally Posted by james739 (Post 264491)
Thanks Ron6519,
Every plumbing fixture needs to be vented to operate properly and is required by code.
How you run the pipes and where you run the pipes are based on you particular set up. You would need to follow your plumbing code to run the vent as well as drain and waste pipes.
In many areas, you would need to hire a plumber and he would need to file a permit for the job. If you can do the work, you would still need to file a permit to have a legal bath.
Ron
Termite 04-23-2009 04:01 PM
Uhhhh...
The black-capped pipe in the first and second picture is a backflow device, and it certainly cannot be "tapped" into. Your shower drain will need to flow through this backflow device if it is a basement shower. It helps prevent backups from the sewer from entering the home and backing up through the fixtures.
KOHNSTRUCTION 04-23-2009 05:28 PM
yeah its like a mono directional valve. open up that floor already and jack hammer it all up run your new tie in where you want it, pour the new cement and get it done. it will come up easy any how you're at the wall not a bunch of work
less than a week end to do it right
james739 04-23-2009 06:42 PM
You make it sound soo easy. Ron was saying I will need to vent regardless. Now, I have to figure out how I am going to vent it before I get started. Any advice will be appreciated
Ron6519 04-24-2009 07:38 AM
If you have no idea what you're doing, have someone knowledgable do the rough in. If you screw this up, the bathroom will need to be taken apart to fix it.
Ron
al's sewer 04-24-2009 08:06 AM
call a plumber
