Can I Connect PB Or Pex Supply Line To Barb With Clamp? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2008, 03:46 AM   #1
can I connect PB or Pex supply line to barb with clamp?
I noticed plumbers use a crimper to connect plastic piping. But would it be possible for me to use a hose clamp to secure supply lines (polybutylene piping) to a barb?
grgryl is offline   Reply With Quote
Old 08-12-2008, 07:43 AM   #2
Registered User
Termite's Avatar
Not really. The crimp you saw the plumber using is under incredible pressure, which squeezes the pipe down with a lot of force. You'd never be able to get adequate force from a typical hose clamp...The PEX tubing is much too solid.
Old 08-12-2008, 09:36 AM   #3
DIY Junkie!!
Rewards Points: 182
If you are determined to use a hose clamp, check out the Onix brand of radiant tubing marketed by Watts Radiant. If you have a torque wrench calibrated in in/ft, you're good to go. Looks like a standard automotive hose clamp to me, but they (of course) caution you to use only their brand of fasteners.
Dugly
YerDugliness is offline   Reply With Quote
Old 08-12-2008, 10:34 AM   #4
Registered User
Termite's Avatar
Onix is a composite tubing that is not the same as PEX.
Old 08-12-2008, 12:47 PM   #5
Do you think a Compression fitting is just as reliable as a crimp? Seems Compression fitting looks easier to connect.
Old 08-12-2008, 01:41 PM   #6
Registered User
Termite's Avatar
I haven't seen a true compression fitting for PEX applications, although they may make them. The crimps are incredibly reliable.
If you're not making an entire house's worth of connections, you might want to take a look at the Shark Bite brand of fittings. It doesn't get any easier, and they don't require tools. They're very reliable from what I've heard.
Old 08-12-2008, 05:01 PM   #7
DIY Junkie!!
Rewards Points: 182
Right, to me it resembles a high grade multi-layer garden hose. I simply mentioned Onix b/c the poster asked about using automotive hose clamps to secure tubing to a barbed fitting and that's exactly one of the two methods recommended for Onix--the other looks like it uses a clamp of a design I know Ford has used for a long time on their radiator and heater hoses and requires, at least according to Watts, a special set of pliers to install on the tubing. The fittings displayed on the Watts Radiant website look for all the world just like the barbed connections I can get at my local Ace Hardware, although Watts states they are proprietary and they recommend you use only Watts supplies connections with Onix.
It sounds to me like this poster has an already existing PEX connection he wants to break and re-connect, in which case IMHO he'd most likely be best off using a crimping ring like the original installation used, but the Shark Bites are certainly another option!
Dugly
Old 08-12-2008, 05:06 PM   #8
Dugly
Actually my existing connection is 1/2 inch polybutylene, but I have Pex lying around and I may need to use that to connect to the PB.
The guy at Lowes said that only crimping would work with Polybutylene and compression fittings wouldn't be suitable, despite the fact that the compression sleeves they sell says it works for polybutylene:
http://www.lowes.com/lowes/lkn?actio...B60&lpage=none
I'll try to find out of Sharks bite can work with polybutylene.
Old 08-13-2008, 04:30 PM   #9
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
I can't find any information about PB on the website, http://www.cashacme.com/prod_sharkbite.php
I do know that PB crimpers work with PEX so the ring size is the same. I would try a Sharkbite and see if it works, if not you're only out a few bucks. A pair of crimpers will set you back around $80-$100.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 08-13-2008, 06:37 PM   #10
Apparently Shark Bite is not certified for PB but it might work (according to other posters).
I was only planning to re-pipe just under one sink; in which case Shark Bite would be more economical.
But I do have PB throughout this duplex and since I've heard how unreliable PB is, I've thought about replacing everything to PEx. If that's the case I'd buy a crimper. I'm just a little upset that the home inspector didn't mention the PB when I purchased the duplex a month ago.
Old 08-14-2008, 07:21 AM   #11
mstplumber's Avatar
Rewards Points: 150
If you decide to repipe with PEX, make sure you check the crimps with a "Go-No Go" guage designed for that purpose. I have found brand new crimpers out of calibration. Most of them are easy to adjust, just don't overlook this critical part of the process.
Mstplumber
Old 08-20-2008, 04:11 PM   #12
Rewards Points: 150
Actually SharkBite fittings are designed to connect CPVC, PB and/or Copper to each other. It is one of their primary functions.
PB has a bad rep for failure so replacing it is probably a good idea.
kgphoto is offline   Reply With Quote
Is it normal to change the upper line at the meter when running new supply line? twilightcall Plumbing 3 08-08-2008 11:10 AM
Supply Line Touching Roof MikeinBurien Electrical 14 07-13-2008 11:26 AM
Relocating water supply line from well Mikedks Plumbing 6 09-22-2006 01:41 PM
add an additional register to a supply line b2v HVAC 1 06-20-2006 06:55 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
