Can Drain Vents Use The Radon Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-09-2010, 11:14 PM   #1
Can drain vents use the radon line?
Our house has radon remediation lines that originate from under the house, pass through the concrete basement floor, and exit through the roof - a fan to draw air through the system is in the attic. I'm in the process of finishing the basement and want to add a bathroom - the house does not have any rough-in plumbing in the basement for a bathroom. Can vent lines for the sink and shower tap into the radon line, which exits the house through the roof?
FTenney is offline   Reply With Quote
Old 06-09-2010, 11:55 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
My guess would be no, but check with local jurisdiction to be sure. Where are you located?
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
FTenney (06-10-2010)
Old 06-10-2010, 07:22 AM   #3
Rewards Points: 1,446
Again, check with zoning, but it will work if the tap in is above the radon fan, namely between the radon fan and the open end.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 06-10-2010, 07:59 AM   #4
You definately do not want to do this, having a powered fan connected into the sanitary vent system will create a continuous negative pressure on the sewer system. It will also redirect air flow from the radon lines into the sewer line potentially cutting off or reducing the flow from the radon collection pipe. You definately want to keep these vents separate. If you can take the new bathroom vent one level up to an existing vent somewhere, that is your best option.
The Engineer is offline   Reply With Quote
The Following User Says Thank You to The Engineer For This Useful Post:
Splicing diswasher flexible ribbed plastic drain line dmwhite509 Plumbing 4 05-01-2010 03:31 PM
Basement bathroom sink drain line on a slight upwards slope an issue? dtran Plumbing 7 01-10-2010 06:05 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
Water and Drain Line Location Material Tester Plumbing 1 11-27-2007 08:40 PM
