Old 06-09-2008, 07:03 PM   #1
Can it be dangerous to cap a drain?
I'm replacing an old cast iron p-trap with PVC and while I'm doing it, I thought about installing a Y joint to run another piece of 2" drain up to my top floor where I"ll be building another shower. I figured since I was already replacing the trap and tying it in to the cast iron drain, it would be a good time to go ahead and put in the Y joint since it'll have to be done anyway to tie in the new shower on the second floor.
My question is, should I put in the Y joint then cement a run of 2" drain and cap it off until I'm ready to start the upstairs shower (in about a month) or should I finish off the drain from the shower I'm working on and then in a month just cut it off and put in the Y joint then? I'm trying to save from having to go back over what I already worked on. I guess I'm concerned that it would either inhibit good drainage or maybe trap sewer gas. I'll try to take a photo to illustrate better.
jayp is offline   Reply With Quote
Old 06-09-2008, 11:57 PM   #2
Doing it myself
Alan's Avatar
There's no reason why you can't do that. Just make sure that the wye portion of the fitting has grade on it (check with a torpedo level for about 1/4 bubble)
Make sure you have enough pipe to glue to later.
The only other thing to do is make sure you're not cutting your wye inbetween the trap and the vent. That would constitute two traps on one trap arm, otherwise known as "Double trapping", which is illegal.
Journeyman Plumber
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
