Can Bath Sink And Service Sink Drain Into 1.5" Branch Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2012, 04:40 PM   #16
Rewards Points: 2,516
Originally Posted by ddawg16 View Post
Hammer.....just wondering....why do you use white PVC when we have to use the black ABS?
I guess because we can here in Ohio
hammerlane is offline   Reply With Quote
Old 10-23-2012, 09:02 PM   #17
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by hammerlane View Post
I've looked in UPC and IPC and cannot find the specific designation for all Laundry sinks, Kitchen sinks, Service sinks..."sinks" to be 2" after the trap arm. Can you provide it?
It's a footnote on the DFU chart.
And now that I look at the newest 2011 codebook, it must have changed.
It used to be a 2" minimum drain for all "sinks"
Are you planning on dumping a washing machine into it?
Journeyman Plumber
Old 10-23-2012, 09:13 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 776
My book says "all sinks" on table 7-5 but it is also not a 2011 edition. But I believe he is under a different code- something about 3 DFU's on a 1.5" line
Old 10-24-2012, 04:36 AM   #19
No washing machine dump into this "laundry sink" in garage....I'd rather call it a "slop-sink"--- somewhere to wash up outside without getting yelled at for trudging dirt into the house.
I believe the code we are under is IPC....not UPC
Old 10-24-2012, 07:54 PM   #20
Doing it myself
Alan's Avatar
DO OVER!
I was mistaken. My book actually from 2008 says laundry sink can be 1.5"
I checked the 2004 book at the shop today, and it says the same thing.
HOWEVER, the 2011 book does ACTUALLY say that the laundry sink requires a 2" drain.
I knew I wasn't crazy, just a little mixed up.
Journeyman Plumber
Old 10-25-2012, 04:43 AM   #21
Here's what I think we're gonna do. Cut out most of the 1.5" and then use the below setup for the 2" garage sink and to pick up the 1.5" lav sink.
Can bath sink and service sink drain into 1.5" branch drain-look-rearward.jpg   Can bath sink and service sink drain into 1.5" branch drain-look-corner.jpg   Can bath sink and service sink drain into 1.5" branch drain-look-north-far-end-even.jpg   Can bath sink and service sink drain into 1.5" branch drain-look-south-close-evev.jpg
Old 10-25-2012, 09:03 AM   #22
Doing it myself
Alan's Avatar
That should be fine....
However, because of the way you're using those fittings on your lav connection, the angle is going to be screwed up.
I'm pretty sure you would need a 1/6 bend to make that straighten out and have decent grade.
Your other option is to add another 1/8 bend and eliminate the funky angle.
Journeyman Plumber
Old 10-25-2012, 10:23 PM   #23
You think? I already have 2- 45's in there, one street and one - hub x hub. There is definitely an elevation change from "F" to the tap of the Wye.
If you have not noticed, where the lav sink enters the rim joist cavity which would be "F" this is at a higher elevation than where the 2" stub out "G" will punch thru the rim joist for the utility sink.
Do not understand what would need to be adjusted for the lav sink portion after the wye
Old 10-26-2012, 09:10 AM   #24
Doing it myself
Alan's Avatar
You think?
Yep, definitely. I tried it lots of times when I was first learning, and it never works out perfectly straight.
To adjust it, you need to put the street 45 into the wye just like you have the other one. At this point, you can either swing the wye/45 combo up on a 45 degree angle if you have room, or you run it flat and offset with 2 more 45's.
Journeyman Plumber
Old 11-04-2012, 08:32 AM   #25
Got the rough in done yesterday.
Can bath sink and service sink drain into 1.5" branch drain-100_9564.jpg   Can bath sink and service sink drain into 1.5" branch drain-100_9570.jpg
Old 11-04-2012, 10:09 AM   #26
Doing it myself
Alan's Avatar
Got the rough in done yesterday. Only issue is a crooked section from the 2" wye back toward the 2 x 1.5 wye.(see photo) It still has proper pitch toward the stack, but it's just cocked laterally. If I keep looking at it I probaby will have to fix it. I suggested dry fitting EVERYTHING together first, but buddy who helped said no need. This was one argument I won.
The stub out from the run of the 2 x 1.5 wye that has the cleanout , was stubbed out like that because buddy has a brand new urinal that may be a future install.
Yep, there is no way to straighten that back out. I see now that you have a ball valve and water line in the way. I probably would have swung the wye up vertical and then put a 1.5" street long sweep 90 on the wye instead. It would have been straight then, and probably fit just right. Hard to tell without dry fitting it though.
Nevermind, I misread your post. :P but I bet the other section is crooked too.
Journeyman Plumber
Old 11-04-2012, 11:08 AM   #27
Could not of swung that Wye to the vertical because of height issue.
Old 11-04-2012, 11:09 AM   #28
What other section? Everything else is straight.
Old 11-16-2012, 01:50 PM   #29
sink base cabinet, countertop and sink finished. Oatey AAV used for venting
Can bath sink and service sink drain into 1.5" branch drain-100_9584.jpg   Can bath sink and service sink drain into 1.5" branch drain-100_9587.jpg   Can bath sink and service sink drain into 1.5" branch drain-100_9590.jpg
Old 11-16-2012, 02:37 PM   #30
Plumber
Rewards Points: 776
Looks good! Now open the fridge and have beer
