-   -   Can anyone tell me what is this I found in my basement? (http://www.diychatroom.com/f7/can-anyone-tell-me-what-i-found-my-basement-44048/)
bayin 05-07-2009 08:44 PM
Hi, I just found this thing in my basement, anyone tell tell me what is it and what it is for? I know it is not sump pump, because I do have a sump pump near at the other end of this room...
Also, I wonder should I pump the water out of the pit? any suggestion is appreciated...
http://picasaweb.google.ca/neilb.web...49259367095202
http://picasaweb.google.ca/neilb.web...49263840440674
http://picasaweb.google.ca/neilb.web...49260324524882
http://picasaweb.google.ca/neilb.web...49268132073410
Scuba_Dave 05-07-2009 08:47 PM
It's an access point to clean/snake the pipes
bayin 05-07-2009 08:53 PM
thanks Dave, another question is, the water level in my area is quite high, especially in Spring time. I wonder what is the proper way to keep this pit dry? as you can see, it's filled with water now ...
bayin 05-07-2009 09:06 PM
Well, there is a pond not far from backyard, which is the lowest point in this area, I guess that is one the reason ..
Scuba_Dave 05-07-2009 09:13 PM
Is that just a gravel bottom?
Seems like that must be a sewer line from the size of it
So opening the cap to drain is out
Does it ever overflow, get a higher water level?
How long have you been in the house?
My sump gets water when it rains heavy & the stream is higher
We've had quite a bit of rain recently & it is fairly dry
I've been working on re-routing drain pipes
And changing the landscaping to drain away from the house
That may possibly help
bayin 05-07-2009 09:35 PM
Yes, it is just a gravel bottom, never saw this kind of thing before.
I've only been this house for a month, to me, I didn't see it has been overflown before, didn't see any sign of flood on the floor, the floor is very dry. But as you can see, there is about 4 - 6 inches of water in there and I just have no clue where this water come from ...
appreciate your help ...
