Old 05-30-2009, 10:54 PM   #1
Default Can anyone recommend a good caulk?
I just installed a new Durastall shower enclosure kit which included the tray, upper frame, 3 walls and door. All parts are made of a non-porus PVC type of plastic. I understand that once everything is together any water that sprays inside should run down the walls and stay within the tray. Just for peace of mind I would feel better caulking the seams between the walls and the tray & the upper frame and new tile surround. The real problem I have is finding a caulk that will stick to the shower enclusure. I've gone to both HD and Lowes and everything they recommend commercially doesn't stick. It literally just rubs off even after it's cured. On recommendation i've tried:
Phenoseal Vinyl Adhesive Caulk
GE Silicone 2 Bath & Kitchen
GE Silicone 1 Bath & Kitchen
DAP Kwik Seal Plus K&B
DAP Alex Plus Acrylic Latex Caulk Plus Silicone
I'm afraid if I use an exterior caulk it may led to mildew growth. Someone suggested it might be a release agent on the moulds but I've scrubbed them with everything.
Can anyone recommend a caulk or adhesive that might actually stick?
lhhandyman is offline   Reply With Quote
Old 05-30-2009, 11:41 PM   #2
Master Plumber/Mechanical
It is all we use.....
You can get it at most Ace and Do it Best stores
Old 05-30-2009, 11:49 PM   #3
Ok so it will stick to PVC securely? I'm almost positive the enclosure is made of PVC type. How is the mildew resistance?
Old 05-30-2009, 11:55 PM   #4
If it is going into a shower use a silicone base caulk either clear or colored to your needs and you will be fine. We also will use the painting blue tape and mask off the area to be caulked so caulk doesn't go everywhere. About 3/16 from both side of the corner or seam.
My company tried this product about 2 yrs ago and have never used anything else. It doesn't shink and sticks to anything.
Old 05-30-2009, 11:55 PM   #5
There is a grade of silicon caulk that is for windows that does not really dry but stays flexible, I can recommend not using that grade on your shower.
I just cannot remember what it is called.
jordy3738 is offline   Reply With Quote
Old 05-31-2009, 12:06 AM   #6
Silicone? That's my problem. Silicone will not stick to the plastic...only the tiles...grout...etc. Do you still recommend using the Big Stretch around the tray and plastic wall?
Old 05-31-2009, 12:12 AM   #7
Yes silicone based caulk.
Old 06-01-2009, 07:22 AM   #8
Old School
cabinetman's Avatar
I've been using Polyseamseal Adhesive Caulk since the early 70's, and wouldn't use anything else. Good for interior or exterior use and sticks to anything. Easy to apply and clean up, and takes paint well...silicone doesn't.
cabinetman is offline   Reply With Quote
Tags
adhesive, caulk, shower pan liner, silicone
More On This Topic
When you’re caulking around a tub or a sink, it’s important to dig out the old caulk first, especially if it’s grown some mold, because that will just go through the new caulk. So, it’s a little bit tedious, but it really is... Read More »
Materials for Painting
Materials for Painting by Expert Village
Hello my name is Grady Johnson. I'm a professional painter and today I represent Expert Village.com Now I'm going to talk a little bit about the materials we need for interior and exterior painting. Now whenever we're painting we know the first thing we... Read More »
Hello! My name is Grady Johnson and I'm a professional painter, and today I represent expertvillage.com. Now we're going to talk a little bit about the materials we're going to need to paint the exterior eaves on our house. Now, whenever you're painting... Read More »
Caulking any gaps before beginning a paint job on the interior of your home will ensure a nice, even finish. There are often cracks where trim meets walls and windows and they will need an application of caulk. Follow these steps to apply caulk on... Read More »
Hi! My name is Christine and I am speaking to you from Simply Lovely Lingerie in Stratford, Ontario. On behalf of expertvillage.com, we would like to talk to you about bras and bra fitting. In this clip we want to take a moment to talk to you about stick... Read More »
Which Caulk to use with Redwood? 1655graff Painting 2 06-17-2008 01:56 PM
Which Caulk for Redwood? 1655graff Remodeling 0 06-16-2008 07:57 PM
To caulk or not to caulk? scraig01 Plumbing 7 04-18-2008 08:35 AM
Bathtub Caulk billinak Remodeling 17 05-27-2007 10:34 AM
Caulk *under* tile layer? carrie brooklyn Building & Construction 0 04-27-2006 10:11 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
