Can Anyone Id These, Waste Drain?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-25-2011, 05:09 PM   #1
Rewards Points: 131
can anyone id these, waste drain??
some i'm know its waste drain, some not sure what it is.
1. toilet
2. pipe between the stud, not sure?
3. drain with black cap?
4. another drain with black cap?
5&6 2nd picture, i'm assuming both are waste drain pipe??
s002wjh is offline   Reply With Quote
Old 12-25-2011, 05:22 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 354
1. toilet
2. probably toilet vent with a auto vent
3. probably a back water valve, whats under the cap?
4. not sure- not a good view. possible clean out
5. clean out for upstairs drain stack
6. cleanout
Old 12-25-2011, 05:27 PM   #3
DIY staff
Rewards Points: 7,174
First is a toilet
Between the studs--air vent/sink drain combination
Can't tell the others without one more photo--take a shot from far back that has all pipes in the picture--Mike---
Old 12-25-2011, 05:27 PM   #4
DIY staff
E-Plumber types fast!
Old 12-25-2011, 05:40 PM   #5
Rewards Points: 131
Originally Posted by TheEplumber View Post
1. toilet
6. cleanout
i know 5 is drain since it connect to kitchen sink.
for #6, if i put a sink cabinet there i can use #6 as my drain ?? since 5&6 has same purpose?
this is whats under the black cap for 3 & 4
Old 12-25-2011, 06:24 PM   #6
Plumber
Rewards Points: 354
As a general rule you don't tie drains into clean outs. Also, you have backwater valves on that line upstream. These are there to protect your basement from flooding should the outside sewer back up. Put your sink upstream from these valves
3 &4 are the backwater valves. If you unscrew the cap, you will finda rubber flapper that hangs down into the pipe. It works like a check valve- sewage will only flow downstream.
I find it a little odd that you appear to have 2 lines exiting your house. They are generally joined together first- odd that you have 2 cleanouts, could one be for a ground water system?
Old 12-25-2011, 06:45 PM   #7
Rewards Points: 131
thanks. i have no clue, since i never DIY plumbing or house remodel before.
i'm using city water so don't think i have ground water system.
so basically I have to cut a hole in the drain pipe and attach a drain pipe to it for my basement sink cabinet?
also 5&6 is on the other side of house relative to 3&4.
P Trap to wall waste Drain - Newbie plumber homeboyslim Plumbing 1 05-09-2011 05:02 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
Frozen Garage Floor Drain Dragon General DIY Discussions 8 01-25-2009 07:07 AM
External Waste Water Drain alangan Plumbing 1 08-11-2005 08:42 AM
