Old 08-27-2012, 12:38 PM   #1
Can An Air Gap Function As A Vent?
I have a 1 1/2 vent line that runs nicely out through the brick veneer that I would love to use for an ERV exhaust line, but its currently venting the drain line from a bathroom.
The same line has an air gap connection in the basement for the water softner dischage. Would this serve the same purpose If I disconnected the current vent line?
kaalapurushha is offline   Reply With Quote
Old 08-28-2012, 08:46 AM   #2
Master Plumber
Javiles's Avatar
vents are vents and are not to be used for anything but, air gaps are to avoid cross contamination with secondary proposes but not venting,
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
ben's plumbing (08-29-2012)
Old 08-28-2012, 09:54 AM   #3
no it wouldn't
Old 08-28-2012, 10:03 AM   #4
Doing it myself
Alan's Avatar
Your airgap connection SHOULD have a trap on it, so the answer is no.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Old 08-29-2012, 08:57 AM   #5
You are right, I didnt notice the very small bend in the pipe. Thanks, I'll have to come up with plan B now
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 03:45 PM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 10:35 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
