Calligan Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2012, 04:59 PM   #1
calligan water softener
how to clear cs code on the circut board. I replaced the seal pack/brine piston. or do I need a new circut board
Killer bee is offline   Reply With Quote
Old 11-21-2012, 05:25 PM   #2
Water Treatment
Rewards Points: 898
You might need to reset the board.
I have a pdf file for a number of control boards that culligan used.
Akpsdvan is offline   Reply With Quote
Old 11-21-2012, 08:09 PM   #3
Rewards Points: 582
did you power it down ..unplug it and start over...ben sr
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water Softeners rickglarson Plumbing 1 01-09-2012 04:10 PM
Water softener or water filter Ext290 Plumbing 7 12-26-2011 10:48 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
