Calcium/Lime Deposit In Shower & Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-14-2009, 05:04 PM   #1
Unhappy
Calcium/Lime deposit in shower & faucet
Hi,
We have 3 bathrooms in the house. In the Master bathroom, on a bi-weekly basis, I have to unscrew the showerhead and faucet to find white deposits on the screens to clean them out to restore water pressure.
However, this does not occur in the other 2 bathrooms or anywhere else in the house. I drained my water heater (2 years old) too.
Any ideas?
Thanks for the help in advance.
nextbond is offline   Reply With Quote
Old 09-14-2009, 07:51 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
If the deposits feel like solid particles between you finger tips, then they're probably disintegrated pieces of the water heater plastic dip tube that carries the water to the bottom of the tank (replace the dip tube).
If they feel soft, then they are most likely just calcium deposits from the water, which can be simply disolved with vinegar.
The fact that these deposits are just going into the usually-first-place-in-the-morning that has water flowing to it is not unusual.
You just need to take care of it.
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-15-2009, 09:43 AM   #3
Mike,
I will check for the particles are solid or not. However, if they are not, how do I dissolve the calcium deposits with vinegar from my water supply?
Old 09-15-2009, 12:33 PM   #4
Water quality'n pump guy
How hard is your water and do you need a water softener?
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Old 09-15-2009, 05:59 PM   #5
already have a water softener....could that be a problem?
Old 09-16-2009, 07:07 AM   #6
Long-Time DIYer
The particles may be calcium and that's one of the hard water minerals that are supposed to be removed by a softener. However, I have a 2-year-old $2,200 system, and I still have a bit of it.
Instead of removing the showerhead or the faucet aerator, you can just tape or "rubber band" a ziplock plastic bag with vinegar on it overnight to dissolve the minerals and then just run water to flush it out.
Good Luck!
Mike
Old 09-16-2009, 12:38 PM   #7
My showerhead has a hose. The particles get stuck on the screen inside the hose that connects showerhead, not the showerhead itself.
Same thing for faucet
Old 09-16-2009, 03:27 PM   #8
A softener that allows hardness through it is undersized for the peak demand gpm the house uses versus the constant SFR (service flow rating) gpm of the volume of resin in the tank.
Gary Slusser
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Shower faucet problem PlainlyJane Plumbing 16 09-06-2009 07:43 AM
Does not fully go from faucet to shower desimonkey Plumbing 1 04-21-2009 02:59 PM
Shower faucet replacement - PVC replacing steel? jdm1 Plumbing 2 11-29-2008 11:38 AM
