Calcium Buildup - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2008, 07:00 PM   #1
calcium buildup
i am getting low HOT water pressure in my house. i have a well with a captive air water tank. my dad thinks that i have calcium buildup in my pipes. how can the pipes be cleaned?
bobcatnj is offline   Reply With Quote
Old 05-20-2008, 07:46 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You can clean and soften the water going into them, but you can't really clean water supply pipes themselves. Water softeners usually remove calcium and magnesium, two minerals that make water hard, clog shower and faucet heads, etc.
If your hot water pressure is uniformly low all over your house, you need to check the cold water supply going into the water heater...cold water pressure in should roughly equal the hot water pressure out. Make sure that the cold water shut-off valve at the water heater is wide open and clear.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-19-2014, 06:26 PM   #3
get calcium out of shower heads?
David S. is offline   Reply With Quote
Old 08-19-2014, 07:36 PM   #4
Rewards Points: 1,772
dO YOU HAVE WHITE BUILDUP IN YOUR COFFEE POT OUR DISHWASHER?
Old 08-20-2014, 12:03 AM   #5
Rewards Points: 13,300
If your trying to post a question David please go back and add your own post, not add onto someone else's.
Two confusing when two people are asking two different questions.
Clear Hardwood Floor Finish With Buildup CuCullin Flooring 3 11-18-2007 03:26 PM
Hot Water Heater Mineral Buildup - Removing Encrusted Element Steve VA Plumbing 1 04-03-2007 08:54 AM
