Cable Through Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2008, 11:17 AM   #1
Cable through drain pipe
Cable guy drilled and ran cable through the drain pipe (see pics). Anybody know how much the plumbing would cost to fix? Thanks
muggyfrost is offline   Reply With Quote
Old 10-08-2008, 12:06 PM   #2
RippySkippy's Avatar
OMG...that's awesome! Not really but the dumb luck to have a cable jack right through the middle of the pipe!
This site isn't for pricing...that's what the local pros are for. Do you have a quote and want someone to help determine if it's in line?
If you want to tackle the project yourself we're all willing to jump in and give you "a hand." For starters you'll need a socket saver, to remove the stub in the fitting, then add a piece back in with an abs coupler.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-08-2008, 12:39 PM   #3
Is the cable company still in business? I would be giving them a call and have them come and fix it including pulling the cable out if the pipe which could cause a clog that would back up into the house.
No response from the company. Call the Better Business Bureau. No response. Take you pictures to small claims. It really gets their attention.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-08-2008, 01:10 PM   #4
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Could he cut the pipe just below and then just above where the wire goes in and put in a new piece of pvc with fernco's? I was planing on doing something very similar myself to add in an additional drain line.
Otherwise, I know it's know of a hack job, but could he just get it really nice and dry, maybe with a heat gun and patch that tiny hole with JB weld putty?
Jamie
jamiedolan is offline   Reply With Quote
Old 10-08-2008, 01:20 PM   #5
It doesn't appear to have enough space on the lower end to get a good grip. I really only like ferncos as a last resort...not that I've had any problems...just like the "real" way better.
Don't know...I really dislike JB weld...never had good luck with it. I wouldn't do it inside a wall cavity like this. I wouldn't want to come back in a few years because..."there's this smell in the room...."
As I think of it...a fitting cut in half glued over the top of the pipe could do the trick with out removing the original pipe.
LMASD
Old 10-09-2008, 09:00 AM   #6
Eibwen
Wow... And the cable guy probably charged ya for doing that!
Looks like just a drain with no pressure..
I would clean the hole up to the next tap size, tap in a plastic plug with some waterproof expoxy. Keep the length of the plug so that it doesnt protrude inside the pipe and become an obstruction for debris later on.
Leave it dry overnight then cut off smooth on the outside and apply another coat of expoxy.
Position your cable tv wall plate so you can see the hole later just to check it.
Sammy is offline   Reply With Quote
Old 10-09-2008, 10:24 AM   #7
Registered User
Termite's Avatar
I would accept nothing less than a paid-in-full repair by a licensed plumber, courtesy of the cable company. Did they just install this or was it found during a remodel?
If you can't hold the cable company liable for whatever reason, I'd still fix it correctly. It is an easy fix and shouldn't cost an arm and a leg. They'll simply cut out a small section of pipe and glue in a new one.
I wouldn't accept a "plugged" repair if it was my house. You'll never regret doing it right. You might regret cutting corners.
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
