Cable In Drain Machine Has Small Kinks, Bad? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2009, 10:30 AM   #1
Rewards Points: 670
cable in drain machine has small kinks, bad?
I have a 1/3 hp drain cleaning machine. The snake has two very small kinks in it (my bad) that are barely visible. I was able to complete a difficult grease cleanout despite the kinks.
My question is, should I replace this snake immediately? I do not know if these very slight kinks seriously weaken the cable or not. Again, you would not notice them if you did not know where to look.
darsunt is offline   Reply With Quote
Old 08-05-2009, 11:58 AM   #2
howdy, i have found that on one half inch and smaller cable, any kinks that can be straightened with pliars are ok. If you heat them and straighten them, there is a risk of the cable breaking at the kink and saying goodbye to you since it will be staying in the sewer line.....
Small kinks do not have be perfectly staightened --- the extra wobble in the cable will help clean the pipe walls... good luck
dave herrin is offline   Reply With Quote
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 07:08 PM
washing machine drain vent problems rebelbull Plumbing 7 03-29-2009 09:18 AM
Washing machine drain --P-Trap ??? DVLCHLD Plumbing 2 09-14-2008 10:23 PM
