Cabinet Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2012, 01:47 PM   #1
cabinet water softener
my water softener developed a leak at the water connection and there also was a leak which seemed to come from the top of the brine tank now the salt bin is full of water my sump pump is right next to it and it bubbled up out of the drain before it kicked in I wondering if the softener can be fixed and if the sump pump could be a reaction from the leaks
hawkrunner is offline   Reply With Quote
Old 02-22-2012, 02:23 AM   #2
Water Treatment
Rewards Points: 816
Photo of the area of the leak.
The extra water could be from the leak that you are talking about getting into the salt tank, then over flowing the salt tank at the over flow if it has one.
Akpsdvan is offline   Reply With Quote
Old 02-22-2012, 11:21 AM   #3
the leak goes down the outside of the brine tank but seems to come out of the softener which is inside the tank, I will check to see if the leak also goes inside. I was informed that the top comes off the softener and to check the seal and top for cracks.
Old 02-22-2012, 01:03 PM   #4
Water Treatment
Rewards Points: 816
What brand is this unit?
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Water Softeners rickglarson Plumbing 1 01-09-2012 05:10 PM
Water softener or water filter Ext290 Plumbing 7 12-26-2011 11:48 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
