my water softener developed a leak at the water connection and there also was a leak which seemed to come from the top of the brine tank now the salt bin is full of water my sump pump is right next to it and it bubbled up out of the drain before it kicked in I wondering if the softener can be fixed and if the sump pump could be a reaction from the leaks
Photo of the area of the leak.
The extra water could be from the leak that you are talking about getting into the salt tank, then over flowing the salt tank at the over flow if it has one.
the leak goes down the outside of the brine tank but seems to come out of the softener which is inside the tank, I will check to see if the leak also goes inside. I was informed that the top comes off the softener and to check the seal and top for cracks.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
