Bypassing A Valve - - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2012, 10:38 AM   #1
Rewards Points: 344
Bypassing a valve -
Does anyone know if they make a "Plug" or " Cap" so I can remove the valve stem and have water pass through the original valve? (minus the stem)
The reason I ask is I have very little room to work on the "input" side, but a lot of room on the "output". I live in an older house on a slab.
What I would like to do is remove the Stems, cap them, and put a modern valve on the output side.
It's not laziness - but more fear of what I would run into should things go wrong...
tribe_fan is offline   Reply With Quote
Old 11-23-2012, 11:31 AM   #2
Rewards Points: 14,026
Just leave the old valve open and add the new one.
Got a picture of the valve your trying to work on?
oh'mike (11-23-2012)
Old 11-23-2012, 12:10 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,644
Ayuh,... In a word,... Nope, no such thing...
Backwater Valve Installation CCCron Plumbing 2 10-24-2014 09:52 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 12:02 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
