Buying A Torch - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2011, 12:28 PM   #1
In a little over my head
Rewards Points: 706
buying a torch
It's time to start sweating copper pipes in my bathroom addition project. Do you guys like the torches with the hose? Or no hose?
http://www.homedepot.com/webapp/wcs/...ord=berzomatic
ratherbefishing is offline   Reply With Quote
Old 11-18-2011, 12:31 PM   #2
Lightfoot's Avatar
Rewards Points: 272
I don't have the hose, but I can see where it might be useful in some situations.
just be sure and go with the Mapp gas unit.
Lightfoot is offline   Reply With Quote
Old 11-18-2011, 01:00 PM   #3
Rewards Points: 120
Hoses can be very handy for difficult to reach places, but IMO, for most of us, a tank mounted torch works fine. Depends what I am doing, but a lot of times a 5-gallon bucket is my tool box; I will grab one of these from that box, a pair of those from that box, a roll of solder from there, some flux, etc. toss it in the bucket, so that I have what I need, without having to carry a bunch of things that I don't need, and a fixed head torch is easy to slip in there as well.
Old 11-18-2011, 02:13 PM   #4
raylo32's Avatar
Rewards Points: 1,290
X2 on the Mapp gas. Much better and faster than plain butane. I also have an air/acety hose torch but for most copper plumbing I find myself reaching for the Mapp gas bottle torch. Get one with the built-in push button lighter.
raylo32 is offline   Reply With Quote
Old 11-18-2011, 02:23 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 778
For work around the house I'd go without a hose. Some of our houses are crawlers. When your dragging fittings and tools while on your knees, a hose just gets in the way. Same is true when your on a ladder. You have to worry about the hose dangling.
I'd be more concerned about the torch head itself. Buy the best you can afford and treat it gently.
Old 11-18-2011, 05:11 PM   #6
Rewards Points: 706
Thanks, all. I went with the top of the line Bernzomatic, no hose, from the Big Orange Box.
Next step, figure out a plan. Then start cutting and sweating. I'm sure I'll have plenty more questions as I go.
Torch down info sjacobso Roofing/Siding 8 07-24-2012 02:54 PM
Help with torch down MB. supperman Roofing/Siding 13 08-19-2011 10:21 AM
Repair and Maintence of a Torch down roof. superdairyboy Roofing/Siding 12 03-29-2011 10:24 PM
Flat roof resurface--EPDM, Torch Down, Cold Applied bitumen mgfuns Off Topic 3 07-07-2010 12:10 PM
Coating over torch down before new decking bobhpete Roofing/Siding 2 05-17-2008 08:39 PM
