Burying CPVC Under Concrete - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2008, 08:31 AM   #16
Journeyman Plumber
Ron The Plumber's Avatar
Costly,
Roll some soft copper, will cost alot less
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-25-2008, 08:38 AM   #17
Rewards Points: 1,062
Exclamation
not feasible
i cannot do that because i will not be doing it all at once.
Phase.1 is the indoor part before my new slab is laid, i will dig under the foundation to stick a piece of pipe protruding some 1-2 ft on the outside. the outside end will be capped, the inside one will be connected or just left above the concrete level to do it later.
Phase.2 is the outdoor part connecting the outside end to the prospective shed, will involve digging.
even if i used soft copper in Phase.1, joining is inevitable as i cannot do it all at once - i need the indoor part finished ASAP and the shed is a nice-to-have for the future.
Old 03-25-2008, 08:45 AM   #18
Journeyman Plumber
Check your code, see what it says, it might be different then mine.
You might be able to rent this type of torch if needed at a rental yard.
Or try mapp gas and try a few test runs before you do the real thing.
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 12:21 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
