Burying CPVC Under Concrete - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2008, 06:46 PM   #1
Rewards Points: 1,062
Question
burying CPVC under concrete
in my municipality CPVC is legal while PEX is not.
Q1: is it (generally) legal to bury CPVC under concrete WITH JOINTS ?
Q2: since i am scared of water supply pipe with or without joints breaking and water saturating the ground, is it feasible to install a small test meter (if such a thing exists) on the line before it goes under ground which would indicate flow in case of breakage ? i would also install a valve next to the meter to disable it in case a breakage is indicated.
thanks,
- a -
Old 03-24-2008, 06:59 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
I have never tried CPVC under concrete. Usually heavy guage copper with insulation
USP45 is offline   Reply With Quote
Old 03-24-2008, 07:03 PM   #3
Question
what can be a downside of CPVC under concrete ?
do you bury copper joints ?
Old 03-24-2008, 07:11 PM   #4
USP45's Avatar
Rewards Points: 150
I just do not trust the strenth and the durability of the CPVC. heavy guage copper even with joints covered with insulation should be around for quite some time.
You may want to waite and see from Ron the Plumber, he usually pops in and out. I dont know his opinion on it, but like I said, I never done it and will not do it just because I have seen it break before.
Old 03-24-2008, 07:17 PM   #5
Question
what do you mean by "heavy gauge copper" ? L-pipe or the size (e.g. 1 inch or more) ?
Old 03-24-2008, 07:24 PM   #6
Send a message via AIM to Marlin
For a test meter simply shut off all the water in the house and look at the water meter. If it's moving you have a leak. There should be shutoff valves at the meter.
Marlin is offline   Reply With Quote
Old 03-24-2008, 07:27 PM   #7
Question
i do not have access to my municipal water meter, it is inside a manhole in front of the house.
there has to be a small test meter of some kind that is threaded/soldered.
Old 03-24-2008, 07:29 PM   #8
Is it a small manhole with a five sided nut on it? If it is just take a pair of channel locks and loosen that nut. Or you could buy a wrench for it.
Old 03-24-2008, 08:01 PM   #9
Journeyman Plumber
Ron The Plumber's Avatar
I don't think you can have cpvc joints under a slab, not here anyways, pex or copper is the way to go, I use pex, no joints needed. If joints in copper under a slab, then the joint/s have the be brazed.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-24-2008, 08:20 PM   #10
Question
how do you braze copper ? is it pretty-much the same as soldering but hotter ?
thanks,
- a -
Old 03-24-2008, 08:29 PM   #11
Journeyman Plumber
Yes hotter and the use of brazing rods.
Old 03-24-2008, 08:36 PM   #12
Question
what do you think i will need in terms of equipment (how much $ roughly) and do you think it is within the DIY domain ? i am very proficient at sweating.
Old 03-24-2008, 10:16 PM   #13
Journeyman Plumber
It's not sweating pipes it's called welding pipe when you braze, it takes high heat, can be done with mapp gas, but using an oxy-acetylene torch will give you the heat needed to braze. Fitting and pipe need to get red hot before rod takes to the copper.
Old 03-25-2008, 08:23 AM   #14
Question
is it worth getting an oxy-acethelene torch you think ?
Old 03-25-2008, 08:45 AM   #15
Question
can MAPP gas be used to silver solder copper pipe ?
i am trying to avoid buying an oxy-acetylene torch.
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
