Bury Fernco Proflex - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2011, 12:29 AM   #1
Question
Bury Fernco Proflex
I live in Sacramento California and need to replace a section of my cast iron sewer pipe with ABS between the house and street. I was hoping to use the Fernco Proflex fittings to connect the CI to ABS but can find anything on Fernco's website that says the Proflex fittings are approved to be buried underground. Can someone tell me if this will pass code in my area? Assuming it will, when I go to backfill, should the fittings be surrounded by plain soil or should I put gravel around them first?
Thanks,
Goose
Goose1 is offline   Reply With Quote
Old 08-02-2011, 11:11 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Thanks,
Goose
Ayuh,... Donno if it'll pass code where you are, but I use 'em, underground all the time....
I backfill with the native soils, Less the Rocks...
To bury or not to bury deck posts with Simpson Strong Tie brackets ribbons55 Building & Construction 7 06-28-2011 11:01 AM
Fernco stack support rtoni Plumbing 3 05-27-2011 11:13 AM
Kohler Proflex AirTub Possible - Subfloor/mortar prep? tub4me Plumbing 3 10-01-2008 03:03 PM
Hubless coupling vs. Fernco Joe F Plumbing 3 09-20-2008 10:56 AM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 06:39 PM
