Burst Of Cold Water While Taking A Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-17-2010, 07:56 AM   #1
sab
Burst of cold water while taking a shower
While taking a hot shower, I will get a burst of ice cold water. It only lasts a couple seconds. This occurs only once or twice during a 10 minute hot shower. And, there are no other appliances in the house using water during this time. What could this mean?
sab is offline   Reply With Quote
Old 06-17-2010, 07:57 AM   #2
A couple words that describes your question (e.g Laminate flooring)
sabsabsab is offline   Reply With Quote
Old 06-17-2010, 08:02 AM   #3
Why did you sign up 2x to ask the same question ?
Old 06-17-2010, 08:09 AM   #4
Rewards Points: 1,514
1. Your shower faucet assembly may have an anti-scald feature that has a hiccup every once in awhile, blending in cold water unnecessarily.
2. There may be an expansion tank on the outlet (hot) side of the water heater and slight changes in water pressure can cause a slug of cooler water to come out into the line. (The expansion tank is necessary and should be on the cold side. Normally it is partly filled with water)
Old 06-17-2010, 08:09 AM   #5
fabrk8r
fabrk8r's Avatar
What type of water heater do you have? Is it a conventional tank type heater or a tankless on-demand type?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 06-18-2010, 09:09 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Betting on the tankless.
Journeyman Plumber
Old 06-18-2010, 12:34 PM   #7
fabrk8r
fabrk8r's Avatar
Yep, me too...sounds like the dreaded "Cold Water Sandwich".
I have to say though that after installing my tankless on-demand water heater several months ago I would never go back to a conventional tank-type water heater. The only time I've experienced the cold water sandwich is when I have the dishwasher and washing machine running at the same time that I'm taking a shower. The only reason it happened is because i wanted to see if I could make it happen. Even then, it was just for about one second and wasn't the traumatic event I've heard it made out to be. In the real world I don't have two water using appliances running when I take a shower.
Old 07-07-2010, 10:49 AM   #8
All tankless heaters have a high temp safety limit switch.It sounds like you have a natural draft unit with the flame set to high for the amount of gpm you are using. If it is a direct vent or so called "Smart Unit" I would look into the flow sensor. I have been a tech for www.eztankless.com 2 years.
plumberbob is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
No cold water out of mixing valve? apex_predetor Plumbing 10 03-17-2010 04:25 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
Water Heater - Water reversed, hot is cold, cold is hot acaciaavenue Plumbing 5 12-09-2009 11:00 AM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
