Burping Drain In Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2012, 07:31 PM   #1
burping drain in kitchen sink
For 33 years the drain never made a sound when we flushed the upstair toilets since I repaired the main pipe to the basement ,I found a cut elbow that looked like it was 33 years old ,replaced all the line from kitchen sink to basement it did not have a vent and I baseically copied what I took out later to find out there was no vent... Can I put a AAV between the drain line and trap to eliminate this =burpping sound , and put the AAV under the sink?
otrock is offline   Reply With Quote
Old 06-01-2012, 07:34 PM   #2
Retired from the grind
Rewards Points: 6,652
You could. My kitchen sink burps and gurgles, due to some time ago before we bought the house, whoever did the kitchen cabinets, cut the lead pipe for the vent. It is on my list of things to fix, when we start ripping out the cabinets, but right now, I am living with it, and have for the past 9 years.
The Following User Says Thank You to gregzoll For This Useful Post:
otrock (06-02-2012)
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Help: Kitchen sink drain is clogged with grease cips Plumbing 5 03-16-2014 10:43 PM
Clogged kitchen sink drain..! abbyqueue Plumbing 3 04-04-2012 07:17 AM
kitchen revamped, help with sink drain plumbing rfire15 Plumbing 6 09-29-2011 08:45 PM
kitchen sink drain hole lucylu092910 Plumbing 1 04-19-2010 08:59 AM
