Burnham Mega Steam Install? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2008, 07:58 PM   #1
Burnham Mega Steam install?
I may not do this install myself, but I am trying to understand it better. Here is my situation. I had a 70 year old oil steam unit that was 2000 lbs. when I finally removed it. It may have been 10% efficient at best. Most of the heat ran up the chimney. When I separated the sections, the bottom 2" connections were rusted with sediment almost solid.
My house is 2600 sf. I did a heat loss and came up with 46,000 btu's. EDR calculation came out to 300 sf (72,000 btu). The boiler I think I need is the Burnham Mega Steam 396. What other calculations do I need to take into account. Is this too small of a unit? Also, I have attached a diagram I created to understand the supply and return.
shadowfarm is offline   Reply With Quote
Old 10-09-2008, 01:36 AM   #2
DIY'r
ScottR's Avatar
Sorry, can't help you with your calcs. Just wanted to say that if you drew/rendered them, those are the best looking examples I've ever seen in a post anywhere.
ScottR is offline   Reply With Quote
Steam shower hook up James Con Electrical 14 09-20-2008 04:55 PM
Converting Steam Radiators To Hot Water johnpar HVAC 4 07-30-2008 03:34 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 08:02 PM
