Burnham Gas Boiler - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2012, 06:18 PM   #1
Burnham Gas Boiler
I have a Burnham gas fired burner that appears to have built pressure. It is leaking from under or inside the burner and the pressure value is full of moisture. I am thinking it is the expnasion tank. The relief value is not that old (nor is the expansion tank)....Where does this water leak from on the inside of burner and what do you think...? Thanks
salmar is offline   Reply With Quote
Old 12-16-2012, 07:10 PM   #2
Items wanted: Time
Rewards Points: 150
Sounds like cracked heat exchanger or bad seal between cells if it has them.
NiNe O is offline   Reply With Quote
New Boiler for an Office - Got Two Quotes, but What Do We Need? Prolow Plumbing 0 09-17-2012 06:10 AM
Trying to wire Honeywell IAQ to Burnham RSM/96 oil boiler 6burgh HVAC 26 11-13-2010 08:21 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 09:55 PM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 08:26 PM
