Buried Copper Supply - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2012, 02:29 PM   #1
buried copper supply
I have a house in chicago. A few years back the old lead supply line inside the house was replaced with copper, all except for a foot long section at the front of the house which is still lead and connected to the copper with a compression connector. Red copper was used, and it's buried about 2 feet below the basement level. The basement has a dirt floor, and I'm getting ready to pour a concrete slab. The ppe is a little more than 2 feet below where the slab will start.
I'm now nervous about this line, as I understand you shouldn't use red copper underground and shouldn't have joints buried, and I know there must be joints under there.
My question is, should I re-excavate it now while I have the chance?
If so, what should I replace it with? K Copper? Or can I use CPVC or PEX?
Will there be any issue connecting to the lead with K, CPVC, or PEX?
My plan is to keep the small section near the front 'open' and not pour a slab over it, and when I have more money, will get the city to bring in a new line from the street, so the lead will be gone completely.
meecect is offline   Reply With Quote
Old 10-24-2012, 06:30 PM   #2
biggles's Avatar
even if it was a home run under that dirt i won't pour concrete over it.is it a crawl space or a normal room height, i say reroute the pipe up onto the over head beams totally out of the trench
Tags
copper , cpvc , lead , pex , supply
Copper supply through unheated garage? CplDevilDog Plumbing 4 06-20-2012 07:33 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Electricity in water supply BimmerRacer Electrical 5 02-02-2010 08:39 AM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 09:21 AM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 10:47 PM
