Buildup On Sump Pump Float - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-06-2012, 06:51 PM   #1
Buildup on sump pump float
Every 6 months or so my sump pump stops working because of a white build up on the float. There is also a lot of this solid "white stuff" on the walls and the pump itself. There are no toilets that drain into the sump basin, however my washer, dishwasher, and sink do drain into it. Does anybody know what causes this and how to prevent it?
admiller97 is offline   Reply With Quote
Old 09-06-2012, 07:09 PM   #2
looks like a huge amount of soap scum, maybe calcium as well from hard water.
The way to prevent this is to drain the grey water from the home into the septic where it belongs.
creeper is offline   Reply With Quote
Old 09-06-2012, 08:11 PM   #3
why do the washer and sink drain into it? definitely against code.
Old 09-06-2012, 08:16 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is it actually a SUMP, or is it a sewer basin intended for discharging the fixtures you listed?
At any rate, it's soap buildup and grease.
Are the fixtures in question high use? Having the basin sitting for lengthy periods of time can cause the buildup to form more rapidly. They are designed to be used frequently.
Journeyman Plumber
Old 09-06-2012, 11:50 PM   #5
we used to put the laundry tub sumps in in western ny. but it only handled the washing machine and laundry tub. change your laundry soap and or your DW soap and see if it makes a difference.
smell from sump pump GEORGIO Plumbing 5 05-11-2012 07:32 AM
understanding the numbers on a sump pump and which one to buy ksimpson Plumbing 0 09-09-2011 07:51 AM
ridgid sump pump float leitrim01 Plumbing 1 09-01-2011 07:41 AM
On Off Indicator For Outside Sump Pump Lawrence Coppar Electrical 31 03-29-2009 01:01 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
