Building Next To Septic Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2012, 02:30 PM   #1
building next to septic tank
Can I build an addition next to a septic tank if I use piers? Closer than the required 10 feet, that is.
Thanks, Rick
rightway is offline   Reply With Quote
Old 01-17-2012, 02:50 PM   #2
Civil Engineer
Rewards Points: 4,770
You need to discuss this issue with your building inspector, or possibly the board of health. What possible use would an answer on this forum do you?
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
plummen (01-17-2012)
Old 01-17-2012, 03:33 PM   #3
distance from septic tank
I've gotten conflicting stories the building inspector never heard of building closer as long as it was on piers. But an architect told me different. The building inspector also said if you move the tank closer to the fields it won't change any pitch on the piping doesn't sound right to me.
Old 01-17-2012, 04:19 PM   #4
Rewards Points: 1,512
You may not build closer than the required 10 feet unless you satisfy some printed exception to the required 10 feet described in whatever document you read about the required 10 feet in.
Old 01-17-2012, 05:44 PM   #5
Civil Engineer
The architect is entitled to his opinion, as are all the folks on this forum. However, in this case the architect's opinion is worthless, as are all the opinions of people on this forum, as the building inspector is the ONLY PERSON on the face of this earth who can offer a definitive opinion on the question. So perhaps you should put it to your building inspector in writing. If you don't like what he says, you can pursue alternatives.
Old 01-17-2012, 06:55 PM   #6
Ok thank you I understand your point.
Residential septic tank rankt Pest Control 3 11-10-2011 02:16 PM
AAV in a DWV system with a septic tank gaaah Plumbing 10 09-20-2011 11:53 AM
septic tank issue..options? jaycenter Plumbing 4 07-02-2010 08:05 PM
Garage over Septic tank and Leach lines canyonbc Building & Construction 11 01-13-2010 10:48 PM
Install manholes (access) hole in concrete septic tank cover rkpatt General DIY Discussions 2 02-23-2009 06:37 PM
