Bucket In Concrete For Full Bath In Basement? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-26-2008, 01:24 PM   #16
Rewards Points: 174
For some reason my house is the only one like that. Go figure.
Not sure about code but I remember hearing that any sewer line replacements could be in PVC.
Leoskee is offline   Reply With Quote
Old 08-26-2008, 01:40 PM   #17
BUILDER / REMODELING CONT
buletbob's Avatar
yes, above gound, how about below ground is that code for your area.
Old 08-26-2008, 01:56 PM   #18
YUP, I totally messed up by missing the height of the main drain from the floor. I made a mistake by "assuming" the pipe went into the floor.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-26-2008, 03:27 PM   #19
Rewards Points: 174
I saw a construction site near by that used large PVC pieces to replace the sewage line going out to the main sewer. I can only assume until I contact the building department. The closed at 4PM.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Basement 1/2 bath--full bath conversion Demochick Project Showcase 2 06-30-2008 09:03 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 12:09 AM
Need help replacing some concrete in my basement. zmurphy Building & Construction 8 01-17-2008 08:10 AM
Leaking Basement - Concrete jeepwillies Building & Construction 2 03-06-2007 07:42 AM
