Bubbling Toilet Last Night - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2010, 08:48 AM   #1
Rewards Points: 63
Bubbling toilet last night
Yesterday/last night we receieved a pretty heavy rainfall (1.2" in about 4 hours). Towards the end of the rainfall, my downstairs toilet starts bubbling (big slow bubbles). The upstairs toilet was fine, and it stopped bubbling by the time I woke up in the morning. Also, when I tried flushing, the bowl just started filling up and I had to turn off the water supply to keep it from overflowing. It did slowly drain again though after that.
I do have a septic and am wondering if that might be to blame somehow.
Any thoughts?
syogod is offline   Reply With Quote
Old 03-26-2010, 09:00 AM   #2
I would have to guess that the septic tank is getting rain water in it and filling up. The main pipe to the tank would then fill up and cause a temporary blockage. Normally, vents are the reason for bubbling, but clogged drains can also cause this.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-26-2010, 09:06 AM   #3
Rewards Points: 63
So then is this something to worry about? or fairly normal?
I have no clue when it's been pumped last (knowing the previous owners as I'm beginning to, I wouldn't be surprised if they never pumped it). I was planning on pumping it sooner or later, but maybe I should make that sooner?
Old 03-26-2010, 09:18 AM   #4
I would try to find out why the tank is getting rain water into it. It could be as simple as the leech field piping backing up into the tank if the ground is saturated. Not much you can do about that situation. If the tank is allowing water in through the lid, it should be resealed. I have had septic systems for years and am very careful about what goes down the house drains and into the tank. This can delay pumping by years.
Old 03-26-2010, 09:00 PM   #5
Rewards Points: 27
You definitely have a "backing up" problem. Like majak.. said, sounds like rain water is causing the lines to back up into the homes plumbing. What happens is, as the water backs up toward the house, air in the pipe is pushing up into your toilet causing the bubbles. I'd start by having a septic hauler/plumber check capacity of septic tank, may need pumping out. That's first, that could get you some immediate relief, then have plumber look for leaks in system to stop future rainwater infiltration.
cm3putter is offline   Reply With Quote
Old 03-26-2010, 09:12 PM   #6
Rewards Points: 1,548
You might dig up the septic tank yourself and remove the hatch and look inside yourself first. If the liquid leve is right up to the top that means either rain water is getting in and/or the leach field is so soaked with rain water that it is no longer accepting outflow from the septic tank.
Normally the water level in the tank is about 6 inches below the top of the tank.
If you don't remember when the septic tank was last pumped and it has been several years, then you might as well have it pumped out now. While the tank is empty you might be able to see whether rain water is entering via the inlet pipe, backing up from the outlet pipe, or seeming coming up from nowhere which may suggest a leak in the tank.
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 08:11 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
bubbling in my toilet...!!!!??? mikebmore Plumbing 3 11-21-2008 05:33 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
bubbling toilet Wahoo Plumbing 5 03-14-2008 05:49 AM
