Bubbling Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2008, 12:48 PM   #1
worm can opener
bubbling toilet
When I drain my bathtub my toilet bubbles a very discusting septic gas. I thought it was my vent so I went onto the roof and attempted to unblock it with a hose and a 10 ft piece of #4 rebar. No luck. There was no blockage I could tell (I have heard of people in the area having mud dobber wasps block plumbing vents.) Any suggestions?
Wahoo is offline   Reply With Quote
Old 03-13-2008, 04:18 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
It sounds like the mainline is blocked up, or starting to get blocked up, clean out the mainline line to fix this problem.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-13-2008, 05:13 PM   #3
worm can opener
Thanks Ron, By clean out the main line do you mean snake it or is it more involved? Since my first post I have done some more reading and found out it could be a full septic tank. The tank was pumped two or three years ago and new tail lines were installed. I figgure cleaning the main line will be the cheaper thing to rule out first.
Old 03-13-2008, 06:21 PM   #4
Journeyman Plumber
Yes snake line to tank, and then if thats not it, then suspect it to be the tank.
Old 03-14-2008, 03:12 AM   #5
worm can opener
Thanks again Ron, Hey, if your not busy this weekend......
Old 03-14-2008, 06:49 AM   #6
Long-Time DIYer
Mike Swearingen's Avatar
It is recommended that septic tanks be pumped out at least every five years. (I have mine pumped out in every year ending in 5 or 0 to keep it idiot proof. lol). If a septic system is getting heavier usage (larger family, etc.) or in very poor soil (such as a clay mix), then it should be pumped more often. Additives are a waste of money. If you have trees or bushes cloe to or over the drainfield, then you can flush a cup or two of copper sulphate blue crystals down about three times a years to help keep roots out. That's really all of the maintenance a spetic system needs, other than keeping the main drain line clear of clogs.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 06:03 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 02:34 AM
