Bubbling Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2011, 06:55 PM   #1
jreist's Avatar
Bubbling Toilet
I am having problems with my toilet. Today I flushed but it would not empty even with a plunger. I tried running the bath and it also would not empty.
I opened the clean out an cleared the pipe to the septic with a snake freeing the water. Added a bottle of Flush Septic Treatment ti the toilet and flushed. After that it flushed OK, but it bubbled in the bowl when I ran the water in the sink. I ran the bath and after several minute the water stopped draining an .backed up and the toilet would not empty when flushed. After 30 min it had drained out.
The septic is only tank is just 2 years ago. Would this be a problem with the septic or with the venting
jreist is offline   Reply With Quote
Old 09-04-2011, 09:32 AM   #2
jreist's Avatar
This morning I went down and had my Sunday bath. After the bath I emptied the tub and started to get dressed. The tub was draining fine and then stopped. I ran the sink and the water filled the sink.
I went down into the crawl space and there was water leaking onto the floor. The water had backed up in the pipe and was leaking around the toilet flange. The water stoped running at 9:20AM. At 10AM the tub was still at the same level. I drained the water from the sink by opening the trap and draining the water. Shortly after this there was a load gush and every thing emptied. Would this be a venting problem?
Old 09-04-2011, 09:40 AM   #3
DIY staff
Rewards Points: 7,174
You don't have your location in the post----
It is possible that your tank and leach field are flooded---
What's the weather been like there lately?
Old 09-04-2011, 09:45 AM   #4
DIY staff
Just reread your post---Might be a clogged vent,also.
Hornets occasionally build nests in the vent pipes so be careful if you are on the roof checking that---
Old 09-04-2011, 09:50 AM   #5
jreist's Avatar
I am located in Rollingdam, NB, Canada. We did have a lot of rain last Sunday with Irene coming through but we are located on a hill, with the end of the leach feild 10ft from a a 45 deg slope.
Old 09-04-2011, 10:08 AM   #6
DIY staff
You may still be flooded----I think calling a 'honey truck' to pump out you tank might be in order.
Leach fields are set up to drain slowly (shallow pitch to the pipes) the unusual amount of rain would be my first suspect, That's the only major change you have had recently---
Old 09-04-2011, 11:07 AM   #7
if stuff drained when vented by removing sink trap i would look at venting first and like mike say be careful out there
The older I get the better I was
Old 09-04-2011, 01:47 PM   #8
jreist's Avatar
I climbed up on the roof and tried to snake the stink pipe but could get it down because there was a 90 deg angle. Could I run water down the vent to clear it out or would that cause more problems?
I went under the roof and checked the pipe, it comes down from the roof and hits a 90 then a 45 then runs along the underside of the peaked roof to a 45 and then goes down to the crawl space where there are vent pipes heading to the bathroom and kitchen sink and washer. would the number of elbows cause problems with venting?
The bathtub snd the toilet would not drain as the when the main pipe filled with water, the toilet has no vent and the bathtube is not hooked up to a vent other then the overflow.
Old 09-04-2011, 02:15 PM   #9
DIY staff
You can use a garden hose to flush the vent.
Please have someone inside watching the bathroom--if the drain is the culprit that water may back up into the tub or sink.
The roof vent should not have a horizontal run in the attic---that is a common cause of clogged main vents---dead birds--leaves and such can settle in the horizontal section and build up ---
Old 09-04-2011, 02:18 PM   #10
DIY staff
Beautiful part of Canada ,New Brunswick---Never been there but a good friends family is from there---the photos are wonderful.
Bubbling Toilet, Pilot Light in furnace out, extremely sick SewerBreath Plumbing 24 05-09-2011 07:38 PM
bubbling noise after toilet filling mlsaephan Plumbing 0 03-02-2011 11:39 PM
Bubbling toilet last night syogod Plumbing 5 03-26-2010 10:12 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
