Bubbling In My Toilet...!!!!??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2008, 08:46 AM   #1
bubbling in my toilet...!!!!???
Hello all....i really have an annoying thing going on...i have a 3br 1.5 bath rancher...and when i use the full bath..which we use most of the time..there is bubbling noise coming from my other half bath from the toilet and sinkwhen we use the big bathroom...there appears to be s traps on the sink(s)....i went on the roof and flushed out the gas exhaust pipe...at least it did not fill up with water...so i guess it is not clogged....dont know what else to do.....please help!!!!!!!!!!!
mikebmore is offline   Reply With Quote
Old 11-21-2008, 09:05 AM   #2
Still sounds like a vent problem. The water may have just pushed the clog down farther. Take a snake and feed it down the vent stack. See if you can feel anything else.
jerryh3 is offline   Reply With Quote
Old 11-21-2008, 03:09 PM   #3
Rewards Points: 874
Could be that your sewer line is partially clogged.
When ours was clogged once, there was not only bubbling from the basement bathroom, water actually came up through the drain in the bathtub and toilet. Your problem is probably less severe at this point, but you should call a plumber before it does get serious.
Ultrarunner2017 is offline   Reply With Quote
Old 11-21-2008, 05:33 PM   #4
It sounds like the toilet that is bubbling is not vented correctly, when you use the other bathe the water and solids pass by the problem toilet, since it may not be vented the solids and water try to syphon the p-trap of the toilet, causing a gurggiling.
zosoplumber is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
bubbling toilet Wahoo Plumbing 5 03-14-2008 05:49 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
