Old 11-08-2012, 03:07 PM   #1
Bubbling heard from toilet when refilling tank
My glorious 4 yo decided that it was neat watching things spin in the toilet and flushed a 3" x 1" x 1" plastic cap which cooperated by spinning and draining.
Unfortunately it got stuck in the bend of the toilet and would not come out using a auger or snake. I dismantled the toilet, leaving the tank in the tub and took the base out to the yard and blew water from the hose in reverse to pop it out.
While putting it all back together, the flange broke and had to be replaced with a PVC flange extender and the wax seal replaced. Everything works but when the tank is refilling it does so very slowly and I can hear bubbling in the tank but cannot see anything.
Any help would be appreciated.
vkeris is offline   Reply With Quote
Old 11-08-2012, 08:33 PM   #2
It was air in the line. Also a kink in the flex line was keeping it from filling at a decent rate.
Tags
toilet bubbling repair
HELP!! Toilet leaking from sides of tank when flushed. teamcampreder Plumbing 17 08-01-2011 10:26 AM
Decorating Behind a Toilet Tank john4153 Interior Decorating 6 06-13-2011 12:47 PM
tighten Toilet Tank Bolts bmenzie Plumbing 5 10-03-2010 12:24 PM
Toilet Tank Movement dschucky Plumbing 2 05-04-2010 01:41 PM
toilet tank fills even after wall valve shut off msmitymite Plumbing 7 12-10-2009 08:56 AM
