Brushed Nickel Vs. Chrome Faucets - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-09-2011, 07:31 PM   #1
brushed nickel vs. chrome faucets
Ok, it's time to replace fixtures in the bathrooms. The trend seems to be brushed nickel and they also sell a lot of towel racks and light fixtures that match.
Saying that, does the brushed nickel finish on plumbing fixtures consist of nickel plating over brass (w/o the chrome on top like the typical plating process), or is it a cast stainless steel and not a plated brass? Nickel plating is yellowish, which these fixtures are not, and also nickel plating typically tarnishes which is why it is almost always topped with chrome.
Are the nickel fixtures clear coated to prevent this, or? I'm basically just curious on what they're selling.
Also, it seems like I read a few yrs back the nickel fixtures were more prone to leaking? I did a search on this and didn't find anything useful.
TIA
Steve_P is offline   Reply With Quote
Old 06-09-2011, 10:39 PM   #2
DIY staff
Rewards Points: 7,174
The 'brushed nickle' is not nickle. Looks like a stainless steel plating with a brushed finish.
I've installed dozens (of not hundreds) of these in the last few years--they hold up well with no tarnishing or yellowing that would be typical of real nickle.
Old 06-10-2011, 12:32 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
They're also not clear coated. The finish is subject to scratching, etc, and if you don't clean it, it'll show water spots just like your chrome does if you don't clean it.
I prefer chrome, and will probably always stay with chrome.
Journeyman Plumber
Old 06-10-2011, 08:25 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
What you are looking at is truely nickel plating over a base material. Whether it's brass or some other material may depend on the quality of the fixture. Stainless cannot be plated onto some other material. Only base materials can be plated onto other metals. Stainless is an alloy, so you can't plate it onto something, however, you could plate nickel onto stainless. Brushed stainless, brushed chrome and brushed nickel are all distinctive finishes and can be told apart from each other, although stainless steel alloys with high nickel content are more difficult to distinguish. Most nickel plated finishes that I've seen on household fixtures are clear coated with a polyurethane to help prevent spotting and for wear resistance. The mechanical guts in faucets are ususally the same regardless of finish, so I don't know why one finish would be more prone to leak problems over another.
Old 06-10-2011, 08:36 AM   #5
Civil Engineer
Rewards Points: 4,568
Alow me to quote from the National Metal Finishing Company:
NICKEL:
Bright Nickel Plating:
Bright nickel plating baths use combinations of organic chemical additives to achieve bright nickel deposits. Bright nickel is used under decorative chrome and other final finishes to cover small defects such as polishing lines and to provide luster. Nickel can also be used as a final finish for certain applications, such as in the plumbing, lighting, and furniture industries.
Matte (Pearl) Nickel Plating:
Matte nickel plating is a uniform finish that is semi-lustrous with low reflectivity. It is also referred to as pearl or velour nickel; it does not have the lines or grainy appearance found in traditional satin nickel finishes. Matte nickel is usually coated with chrome, black nickel or another final finish. It is used in the plumbing, optical, lighting, and automotive industries.
Satin (Brushed) Nickel Plating:
Satin nickel plating is a nickel finish that is semi-lustrous with some reflectivity. It is also referred to as brushed nickel; it does have lines or a grainy appearance that is applied by mechanically polishing the surface before or after the nickel plating. It is used in the plumbing, lighting, and furniture industries.
Bright Black Nickel Plating:
Black nickel is plated over bright nickel to give a lustrous black appearance. It is brighter than black chrome and covers recessed areas better. Since the black nickel coating is quite thin, corrosion resistance is somewhat limited. To improve corrosion protection, the black nickel or bright nickel may be applied over electroless nickel, but the black color may not hold up in severe environments. It is used for optical components, gun sights and components, lighting and plumbing fixtures and some automotive parts.
Matte Black Nickel Plating:
Black nickel is plated over matte nickel to give a grayish, non-reflective appearance. It is slightly brighter than black chrome and covers recessed areas better. Since the black nickel coating is quite thin, corrosion resistance is somewhat limited. To improve corrosion protection, the matte nickel may be applied over electroless nickel, but the black color may not hold up in severe environments. It is used for optical components, gun sights and components, lighting and plumbing fixtures and some automotive parts.
From reading other manufacturer's sites, it appears that brushed nickel is always an applied finish, which gets its appearance from a mechanical technique used on the plated product. The nickel can apparently be applied over virtually any metal, as there were examples of brushed nickel over copper shown.
I am the owner of several Kohler faucets (this is NOT an advertisement for Kohler, although I have been very happy with the faucets). Two of them are brushed nickel finish, one is chrome. We have had two of them for at least fifteen years, one of them is brushed nickel, one is chrome. Neither has tarnished, chipped, flaked or in any way deteriorated, despite virtually no care. Neither has leaked. I cannot say whether competing manufacturers offer similar quality levels.
Old 06-10-2011, 01:13 PM   #6
Rewards Points: 1,016
I prefer the chrome finish - usually cheaper as well.
Old 06-20-2011, 11:06 PM   #7
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Tell me about it, we are doing Brushed in hall bath and its almost double for some stuff than Chrome...
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 06-21-2011, 12:21 PM   #8
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Originally Posted by Steve_P View Post
Ok, it's time to replace fixtures in the bathrooms. The trend seems to be brushed nickel.....
Just my two cents, but that in itself is a reason not to do it. Three years from now when it looks dated you'll be kicking yourself for not going with classic chrome.
Chrome paint on plastic Thurman Painting 3 08-24-2010 01:17 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 09:28 AM
Problems replacing two handle shower faucets bear creek Plumbing 3 02-04-2009 07:41 AM
Repair/Rebuild antique faucets bofusmosby Plumbing 8 11-25-2008 06:59 PM
satin nickel - the new <faux> gold? joeyboy Interior Decorating 13 10-10-2007 05:30 PM
