Brown Water!!?....what From?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2010, 09:07 PM   #1
Brown water!!?....what from??
I have brown water coming out my tub faucet & cannot understand why it is so.
Been working on repairing a pressure balancer in the shower faucet, went to turn back on & now get brown water out just that faucet. any hints??
JW_17 is offline   Reply With Quote
Old 01-09-2010, 05:23 AM   #2
My guess is there is steel/galvanized pipe somewhere in that line. Not unusual for the drop from the valve body to be steel, although it should not be, replace with brass or make up a copper pipe.
Old 01-09-2010, 05:31 AM   #3
Send a message via MSN to RubyRose66
Need an Answer with Plumbing issue due to cold weather
Just Bill, I need help.
RubyRose66 is offline   Reply With Quote
Old 01-09-2010, 07:41 AM   #4
Rewards Points: 1,514
You stirred up sediment in the pipe while you were working and also if the water was turned off for that branch, the inrush of water when you turn it back on can stir up sediment.
Let it run for several minutes and it should clear up.
OT: When the water company or city flushes the water mains or when the fire department fights a fire, sediment all through the water mains will be stirred up and not all of it gets flushed out the hydrant. People up and down the block can get brown water for an hour or so
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 01:56 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
