Broken Waste Line Thread - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2012, 09:58 AM   #1
I am in an old building replacing the trap in the bathroom vanity. My issue is the waste line coming out from the wall. When I removed the pipe attached it crubled and left the threads a bit broken up. Now when I try to attack the new fixture it wont catch. Replacing the pipe in the wall would be a major project that I am hoping to avoid. Is there something I can do to resolve this, put in a smaller fitting and something like prodope? Since its a waste line should that make it somewhat of an easier fix?
nexty76 is offline   Reply With Quote
Old 05-25-2012, 11:48 AM   #2
I=E/R
a7ecorsair's Avatar
You really need to post a picture. It's hard to advise when we don't know what is looks like.
a7ecorsair is offline   Reply With Quote
Old 05-25-2012, 11:50 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 684
Ideally you would remove the trap arm from the tee in the wall and convert it to plastic by using a MIP x plastic adapter.
If that's not possible, cut the bad threads off and use a fernco to attach new pipe and trap.
Old 05-31-2012, 06:07 AM   #4
For some reason every time I try to upload pics the dialog box comes up and times out after upload. I can email them if necessary. Basically the female pipe I am trying to access is about an inch in from the tile on the wall. When trying to attach a male 1.5 inch it doesn't catch because the threads are broken. What can I do to attach a trap to this pipe without replacing the whole thing. If possible send a link to the product or technique you think would work, as I'm not overly familiar with some of the products that have been mentioned already. Thanks.
Old 05-31-2012, 07:27 AM   #5
Rewards Points: 13,750
Are you sure all of the old nipple has been removed? If it's just some rust a Demel tool with a wire brush wheel may clean it out.
If I can see where a thread got messed up I've used a Dremel cut off wheel to carefully clean them up.
A curved dental pick can be used to help clean up any low spots.
Old 05-31-2012, 09:29 AM   #6
I went at it the other day by hand with a small wire brush. Can I buy a wire brush bit that will attach to my screwgun? If this doesnt work what is my work around?
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
Whirllpool Refrigerator Broken Water Line due to heat drrjstull Appliances 4 09-05-2009 11:54 AM
waste line in basement slab 7474 Plumbing 6 12-11-2008 06:38 AM
