Old 11-15-2012, 02:44 PM   #1
broken tub drain
Got a drain w ith broken crossbars. Do i sawzall it out?
biggscoo is offline   Reply With Quote
Old 11-15-2012, 03:00 PM   #2
broken tub drain
that's usually what i had to do once the center broke out. i would cit a slit in an easy to get to spot mostly through then stick a screwdriver in the slot and the strainer would usually snap the rest of the way. depends on if it's cast or stamped.
The Following User Says Thank You to DannyT For This Useful Post:
biggscoo (11-15-2012)
Old 11-15-2012, 04:46 PM   #3
An old Tradesmen
broken tub drain
Moved to Plumbing forum.
Old 11-16-2012, 07:54 PM   #4
Barry
broken tub drain
Careful not to cut into the tub. You may have better luck with a hacksaw blade. Cut a slit in it then insert a cold chisel in the slip and rap it in the direction you would to unscrew it (counterclockwise) and it should loosen up. You could start with some WD-40 or penetrating oil.
Barry
Tub Refinisher is offline   Reply With Quote
Old 11-16-2012, 10:58 PM   #5
broken tub drain
they make spread device to remove drain lowes sells one
http://www.lowes.com/pd_272239-943-0...t_avg_rating|1
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 11-16-2012, 11:01 PM   #6
broken tub drain
never used the lowes one but i use this one all the time
http://www.rectorseal.com/Golden-Ext...Drain-Tool.php
Old 11-16-2012, 11:02 PM   #7
broken tub drain
Sure there's not a nut under the tub holding it in place?
Old 11-17-2012, 04:30 PM   #8
Plumber
broken tub drain
Its not a "nut" but you do have a female thread on the drain.
If you bugger up the female thread your looking at replacing the waste and overflow.
This is what is under the tub.
DidIDoThat is offline   Reply With Quote
broken snake in shower drain Wa! Plumbing 2 11-17-2011 07:40 AM
Tying into 50's style clay drain tile perimiter system/exposed Pit / Wall membrane alecmcmahon Plumbing 6 12-29-2010 08:23 AM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 11:40 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
