-   -   broken tub drain (http://www.diychatroom.com/f7/broken-tub-drain-163438/)
biggscoo 11-15-2012 01:44 PM
broken tub drain
Got a drain w ith broken crossbars. Do i sawzall it out?
DannyT 11-15-2012 02:00 PM
that's usually what i had to do once the center broke out. i would cit a slit in an easy to get to spot mostly through then stick a screwdriver in the slot and the strainer would usually snap the rest of the way. depends on if it's cast or stamped.
beenthere 11-15-2012 03:46 PM
Moved to Plumbing forum.
Tub Refinisher 11-16-2012 06:54 PM
Careful not to cut into the tub. You may have better luck with a hacksaw blade. Cut a slit in it then insert a cold chisel in the slip and rap it in the direction you would to unscrew it (counterclockwise) and it should loosen up. You could start with some WD-40 or penetrating oil.
Barry
jaydevries 11-16-2012 09:58 PM
they make spread device to remove drain lowes sells one
http://www.lowes.com/pd_272239-943-0...t_avg_rating|1
jaydevries 11-16-2012 10:01 PM
never used the lowes one but i use this one all the time
http://www.rectorseal.com/Golden-Ext...Drain-Tool.php
joecaption 11-16-2012 10:02 PM
Sure there's not a nut under the tub holding it in place?
DidIDoThat 11-17-2012 03:30 PM
1 Attachment(s)
Its not a "nut" but you do have a female thread on the drain.
If you bugger up the female thread your looking at replacing the waste and overflow.
This is what is under the tub.
