Old 01-27-2008, 07:47 PM   #1
Broken trip lever in tub
The trip lever on my tub's drain snapped off. I don't think it even worked to begin with. I am thinking that I will just unscrew the two screws and buy a replacement cover with the guts. Are these difficult to replace? or should I be consulting a plumber?
cibula11 is offline   Reply With Quote
Old 01-27-2008, 08:19 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Easy fix.
Just unscrew the two bolts and lift, wiggle and pull out the assembly.
If the assembly looks good and you can clean and lube it, just replace the trip lever, cover and bolts, and attach the old stopper assembly with a cotter pin to it.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-28-2008, 02:54 PM   #3
I just got some advice on replacing the trip lever a few weeks ago on the forum. Its definitely an easy fix as Mike said. I think it cost me about $6 for the new trip lever.
jte1130 is offline   Reply With Quote
broken lug studs LanterDan Automotive Repairs 19 02-01-2009 09:13 PM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 08:58 PM
Dilemma - Trip switches tjchelsea Electrical 1 08-17-2007 08:05 PM
Broken Drill Bit Freelancer General Discussion 15 03-29-2007 05:01 PM
Broken Brake Shoe powrus Automotive Repairs 11 01-16-2007 06:40 PM
